Just finished a rebuild of my 87t. My battery light is constantly on when the car is running. Put a new battery and alternator in this morning, same problem.
I went to Advance and had them check the charging system, the guy said something referring to a low reading on the alternator's charge output.
I left the battery (old one) hooked up in the car overnight, dead the next (this) morning.
Also the brake light is on too, it only brightens when I raise the ebrake handle. Fluid is full, bled brake system last week.
Checked to see if I missed a ground wire somewhere, couldn't find any.
Checked the wiring harness, couldn't find anything out of place.
Do you think this is a short somewhere?
