Basic coverup of 5 speed swap
koldfire08
139
Las Vegas
I understand this topic is ALL over. But I have yet to find thurough pointers and techniques while doing the swap. Will I run into any common issues and how to attack them. Pointers that you began to use which made some task easier/more efficient.
So far on my list I have.
F1 Stage 3, 6 Puck disc
Pilot/throwout bearings
Lightweight flywheel
1pc Alumunum DS
Slave/Master cylinder
Clutch hose
Pedals
Throwout hub
Clutch fork and mount
If there is anything I'm missing feel free to let me know. I have only purchased the R154 with no housing or shifter aswell
Does the Master Cylinder I buy differ if I have ABS or not?
Any and all help will definately be appreciated. Thanks!!
Jose
fixitman04
fixer of all things !!
Sep 18, 2008
787
north dakota
IJ.;1538489 said:
ABS=Brakes, nothing to do with a 5 speed swap.
not completely, you need the sensor for abs if you have it on your car. the r154 has the sensor ring in it even if it did not have abs though, just not the sensor on non abs cars.
what do you have to do to keep cruise control is what i need to know?
1pc Alumunum DS
Clutch hose
Pedals
Throwout hub
Jose
Context is important......
fixitman04
Sep 18, 2008
787
north dakota
true.
just figured id add to the thread
"ABS=Brakes, nothing to do with a 5 speed swap. "
and context is important in an answer as well!
koldfire08
139
Las Vegas
kneedragger85;1538551 said:
Pressure plate?
Yeah, it comes with my Clutch kit.
---------- Post added at 11:16 PM ---------- Previous post was at 11:15 PM ----------
Sorry, i was referring to that sensor, i saw something about the sensor on DM but i wasn't sure if i REALLY need it or if it affect's operation of the vehicle at all?
I assumed if a car had ABS then it's a no brainer to replace the Auto with a 5speed from an ABS car, the only mention of ABS in the original post was about the Clutch master cylinder.
I can only go by what's posted I'm not a mind reader.
koldfire08
139
Las Vegas
I understand, and forgive me for my bad words of choice.
I just don't have 150 to fork out to DriftMotion for their ABS sensor.
Was wondering if it's a definate part that i need.
koldfire08
139
Las Vegas
IJ.;1538663 said:
If you want functional ABS then yes, "should" be able to find all the bits you need from someone here that's killed an ABS equipped trans just pop a post up in wanted.
Awesome, alright. You've been a big help!
I think i've seen your name as Ian? But wouldn't want to come out of the blue calling you that.
But anyways, Thanks again for the help!
