Base fuel pressure??
BJ91T
810
Baton Rouge LA
Just wondering what base fuel pressure should be at the AFPR with my mods at idle with the vac line removed from the regulator.
Thanks In Advance
here are my mods
Walbro 255 12V
stock injectors
lexus maf
FIPK
3 inch turbo back
AFPR kit
57 trim ct-26
grimreaper
2,180
Dallas
stock 35psi or so, id try to please vf's at idle at least and see where it lands you on the top end (puts me wayyyyy rich)
tissimo
Stock is boring :(
Melbourne, FL
43-45 psi w/ vac off is stock.
Adjust it to where you need though (isn't that why you bought it?) I wouldn't go below like 32-35 psi though.
Piratetip
Far From Maddening Crowds
1,177
69
MKE, WI
It's hard to give you a good base fuel pressure number.
All Supra's with your setup will be slightly different from each other.
You need to monitor your vf like grim said, this will give you what you need to know.
