I have a bad drivetrain promlem and I dont know how to fix it... So here is what happens: using the clutch in first the car shutters a little bit. If I try to launch the car the whole friggin car shakes. Your probably thinking its driver error, but that is the slightest of the problem considering I used to be able to launch just fine. The rest of the shifts are very harsh, and occasionaly, if i am flooring it the car will do a little thing where it's almost as if someone pressed the clutch pedal down then back up really fast. so it kinda jerks me back and forth, just once though. keep in mind this may happen long after my last shift. So I take it to the best place in west michigan, after a week with my car, he says: it's because it is an aluminum flywheel and the metals have different densities. The car has an RPS Stage 3 clutch, and a fidanza aluminum flywheel. I will admit, the problem did get worse after I replaced the clutch assembly and the flywheel, but the problem was deffinetly there before with just the stock clutch and flywheel. My mechanic said thats because the clutch was going out. I've never heard of other people haveing this problem with this flywheel... Any advice would be great because I officialy feel screwed.
