I've got fuel (haven't checked pressure) the plugs are soaked after a few cranks though, I've timed it like haynes and tsrm states (crank at 0', piston at the very top, cam gears lined up to top of intake cover #2, CPS where the drilled portion lines up with the groove and contact points are about touching). I do get spark but it is a very weak orange spark not blue, and the resistance at the connections are .7 ohms (books say .2 ohms - .5 ohms). She still won't start. The only code I am getting is 51, which is AC switch or Neutral safety, but it's a manual, so I'm going with it is the AC for that code. Any thoughts?
