What would cause a car to backfire before the engine actually turns over. (when its trying to be started)
Valve timing? How would i go about fixing this?
OneJoeZee said:Sounds like your timing is out of wack.
nosechunks said:try retarding the ignition timing. if it goes away then double check where its at.
nosechunks said:only other way combustion could escape would be threw a valve thats open at the wrong time.
Fixednosechunks said:well if you retard it and it lessens/goes away its pre ignition via spark. if it doesnt go away then its not ignition related.
maybe your damper timing marks are off. put a piece of Vacc hose down #1 and check the marks.
IJ. said:Fixed![]()
TobyCat said:this happened to MrBaboon when he assembled his motor back together. The CPS was 180 degrees off. We couldn't figure out why his car sounded so fracked up on startup ... Nashman had a good chuckle and told us the problem![]()
