Backfire pre-startup?
s383mmber1
3,614
Somers New York
What would cause a car to backfire before the engine actually turns over. (when its trying to be started)
Valve timing? How would i go about fixing this?
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,777
Long Island, Ny
well if you retard it and it lessens/goes away its pre ignition via spark. if it doesnt go away then its not ignition related.
only other way combustion could escape would be threw a valve thats open at the wrong time.
maybe your damper timing marks are off. put a screw driver down #1 and check the marks.
maybe your damper timing marks are off. put a piece of Vacc hose down #1 and check the marks.
Fixed ;)
Isphius
Supra-less :(
May 30, 2006
359
long branch
yeah, from what it sounds like i would make sure your cam gears have the right marks, and that your damper mark is in the right place. It could be as simple as that. Every symptom you describe to me sounds like an ignition problem. But thats just what it sound like, never seen the car run in person thou! but id like to
TobyCat
470
Vancouver BC
this happened to MrBaboon when he assembled his motor back together. The CPS was 180 degrees off. We couldn't figure out why his car sounded so fracked up on startup ... Nashman had a good chuckle and told us the problem ;)
s383mmber1
3,614
Somers New York
Thats very interesting....my CPS is DEAD on at 0...
Ill retard it 180 and see what happens later tonight...
bwest
Drafting, not tailgating
May 18, 2005
502
HippieTown, CA
Here:
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=IG&P=24
then:
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=IG&P=21
lastly:
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=IG&P=20
In doing it by the book, you should be close to 10btdc. If you do it with the cam covers off, you can get it almost exact. In doing it this way with the covers on, I was @6btdc. Make sure to double check (w/ light) after the car is running and warm - this will have an effect on how it starts.
