Awkward fuel cut problem.
IRONMAN
58
Mobile
Fixed all codes including the code 52 today. The only code left is the afm code 32. I checked the afm with a multimeter and it's bad. Well not bad but completely mutilated. It does not check out with any resistances on any leads.
IRONMAN
58
Mobile
All codes fixed exept the knock sensor gives a codes after it runs lean under boost (obviously). After cleaning and rebuilding all of the tank pieces and rewiring the afm, knock, tps, temp sensors, and most grounds it rans much much better. I later found out that the fuel pump is actually not strong enough. Since it has 160000 miles on it and then sat for 3 years I kind of expect it. So My next step is replacing it with the Walbro.
