awesome times setting TPS (not really)
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Had you done it using the diag system like Nick is suggesting all you would have needed to do is loosen the TPS. No moving of hoses or disconnecting of anything. Even more important is you wouldn't have made the pin mistake because no measuring would have been involved. Nor would the TSRM have been needed. The hassle is having to look at the MIL although two people solves that problem. My own method is to measure voltage on IDL because voltage is what the ECU deals with.
IndigoMKII
2,181
Madison, Virginia
What is the voltage on the IDL that the ecu is looking for? I know most people with SAFC's will go by the IDL voltage on screen when setting the tps too.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
It's my understanding the SAFC only displays VTA but having never messed with one I could be wrong.
Since IDL is pulled up internal to the ECU it will be high when the TPS switch is open (throttle off idle, input floating) and low when the switch is closed (throttle on idle, input grounded). The TSRM, at least some I've seen, say IDL will be battery voltage when high while others say it'll be 5 volts. I have never seen one be battery voltage nor, since it's part of the EFI sensor system, does it makes sense it would be.
Put simply it'll be close to 0 volts at idle and 5 volts at all other times. Having never played with it I don't know exactly what level the ECU judges the throttle to be off idle. I'm assuming it's near whatever the 2K ohm max spec on the TPS figures out to be or whatever the "legal" high is for the type of logic involved. Probably around 1.8 volts but it doesn't really matter because of the pull up.
When the TPS is set properly VTA will vary from around 200 mv at idle to appx 3.6 volts at WOT. This is in contrast to the nearly 5 volts the book states.
Insidious Surmiser
Formerly 89jdm7m
May 12, 2006
2,172
Oceanfront
that sounds pretty simple either way... it was just me working on it... the way I did it was REALLY simple too. like I said, all I had to move was 2 vacuum lines, and unplug the TPS (still don't think you even need to do that to see if there's a break in continuity, if there wasn't it'd mean your harness was shorting) the key to getting the TPS loose w/ out moving everything was a phillips tool shaped like an allan key
but yes, the safc displays VTA for sure... I used to use that all the time on the highway (in conjunction w/ vacuum/boost gauge) to hit 30mpg...
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
If it was simple you wouldn't have spent so much time trying to figure it out and this thread wouldn't exist. And I said you *risk* measuring circuit resistance by not disconnecting. Point is it's very bad technique yet you keep telling us what a sierra hotel mechanic you are. I r corn-fuzed...
8,898
I read it in one of the older books, like 850 or something. But I am not going downstairs to read it.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
See, there again is more documentation that shows IDL may be connected to +B and that it may be anywhere from 5 to 12 vdc when pulled up. I've never seen anything except 5. Go figure. Maybe we can convince 3p to poke around an ECU and see whether that input is pulled up by +B or Vc
8,898
I am going after the book. I don't have anything to do right now. Babysitting....
In 852, which is is later and has the 1MZFE and other OBD2 in it has a spec. They say 0V at idle, and B+ when open. And that might not apply to the older TCCS.
http://www.autoshop101.com/forms/h33.pdf
Page 3 of 8. Or page 2-15 in the hard copy.
8,898
IndigoMKII;1926999 said:
Thanks, I actually have that printed out as I found it the other day and said "DOH" lol
That was one of my lesser moments if you will.
He has everything that I have, and then some. I have nothing on hybrids, other than what I cribbed from him.
Insidious Surmiser
Formerly 89jdm7m
May 12, 2006
2,172
Oceanfront
lol, hotel mechanic sounds about right (I've done that before)... I've got the certifications, but an extreme lack of experience, and pretty much no tools. it was simple as hell, you of all people ought to know. the extent of complexity is that I had the diagram upside down. flip it the other way and it's no issue at all... I didn't need to measure resistance anyhow. all I needed to know was if the circuit was closed or open.
