Average Yearly Maintenance/upkeep costs?
turbo4toy
208
Los Angeles
LOL......Supra is japanese for $$$$. I spent over 2K on just tires the last year that i was using as my DD. Honestly the upkeep costs are probably just as much as any other car. It's more when you get the go fast bug and start buying all of the performance parts when it all starts adding up.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Draken said:
thats 7 quarts of royal purple + filter...15w40 royal purple is $6+ per quart, that gives me 5 quarts to dump in, and 2 extra because my valve guide seals leak slightly and i go though about 1 1/2 - 2 quarts per oil change....don't call someone ignorant if you don't know what kind of product someone is using...and like i said, i drive A LOT and put a lot of miles on my car, and i drive it hard, so i want something that i know is going to hold up in my oil pan, thats why my choice of royal purple oil (and all other fluids), he asked what our cost is, thats my cost, just that simple
Fair nuff but being called ignorant isn't a slam, it simply means you don't know any better. Why would you change expensive syn oil every 3K no matter how many miles you put on the car? Why would you use such an expensive oil if the car burns it? Why would you even use 15-40 in the first place? In Michigan no less? Because the car burns it? Why don't you repair the car? And do you honestly believe RP is the only oil that'll "hold up"? What do you base that belief on? Sorry, but your statement has ignorance written all over it.
It's your car (and your money) so you can do as you please. Nor do I have a problem with $6/quart oil. The oil I use costs almost the same, I'm just not foolish enough to throw it away after 3K miles. You say you need an top of the line Group V synthetic that'll hold up, yet you believe that same oil only does so to 3K miles. Does that make sense? Does it reveal even a basic knowledge about what happens to a motor oil in service? I mean come on, the cheapest SM rated Group II dino oil on the market will "hold up" to 3K miles no matter how much you beat on it.
He asked for costs and you contributed. From where you sit you done good but your costs are not representative of owning the car because they're not represenstative of someone who understands the right way to care for the car, nor the way to get value while still doing right by it. You might as well tell him the cost of putting new tires on every 3K miles or what it'll cost to gold plate the wheels. Since ownerships costs are behind his asking the question in the first place what you're doing makes the data point next to worthless. I'd go so far as to call it misinformation. All it accomplishes is him thinking the costs are more than they should be.
As for yourself, you have two choices: You can get bent or you can get educated. I suggest the latter.
91T breezen'
ROMNEY/RYAN 2012
Apr 4, 2005
1,149
NOYFB!
I've got about $4500.00 into my car. Gas is about $100-$140.00 per month, depending how much I drive her, oil is pricey...Amsoil 15-40, every 3000 miles, + filter er, $50.00...Insurance is pretty cheap for me $79.00 per month(full coverage!) Odds and ends, I'd say about $400-$500.00 per year. Not the cheapest car to own, but she's been pretty reliable, and could have been alot more expensive. I count my blessings. I figure I've got at least another $10,000 left to go, to get her to where I want...550whp, and 550+ rwtq!:icon_razz
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Btw, since we're jawing about oil here's something those of you who care about cost versus value might like to know.
Valvoline is giving away 5 quarts of either their MaxLife regular or full synthetic free. That's right, 100% full PAO syn oil free. It can be had in 5-30, 10-30, or 10-40 grades. Don't let the high mileage label fool you, both of these are excellent oils that can be used in any mileage engine.
The regular oil is a syn blend (18-20% PAO) while the full syn is just that. Go to the Valvoline website and print out the mail in rebate form then go buy either 5 quarts or a 5 quart jug of either oil at your local Wally World or PepBoys. Better hurry though, the offer is limited to the first 100,000 rebates.
Suprastic
727
Manitoba
My acr is a DD in the summer and for the past three years I haven't had to do anything other than regulary changing my fluids. Everything I replaced was due to normal wear and tear like tires and brakes. I found that my car has been soo reliable to me that I was able to concentrate on doing minor repairs to the body and repainting it. I also have been anble to completely change my interior around. The interior will be finished this tommorow and the car will be painted by April 17th. By then it'll look and feel like a brand new car. I replaced the engine three years ago after I blew the HG. Since then regular maintence and no other problems what so ever. I love it.
Draken
57
michigan
I used to run castrol ful systhetic, i would get between 270ish and 280ish miles out of a tank of gas with mixed highway and city driving, someone recomended i try RP, so i did, 2nd change i now get between 320ish and 330ish miles per tank, same mixed driving. you asked why i use 15-40? because i use less of it, with 10-30 would go though about 3 quarts per change, so i raised the weight that i'm using and i burn a little less oil...
now do i believe that RP is the only oil that will hold up? no i do not, i know there are a lot of good oils out there that would not have a problem at all, i run what i like
i change my oil and filter ever 3000 - 3500 miles because thats my choice as you said, but with all the cars i have had i have had:
1. engine blow because an oil like blew and a 1/4 inch like can dump a lot of oil real fast when its at 60psi
2. blew the apex seals in my RX-7 from running to high of revs in it while racing when the engine already had 223K on it with no rebuild
These are repesentative of owning the car, because i do own the car, this is just how I treat my cars, and my treat me good. yes, I run expensive oil, yes i change said oil every few thousand miles along with the filter, but as has been said, my choice, i personaly don't agree with changing the oil every 25k - 30k miles, but thats your choice.
as for my data being "worthless" is is a long way from that, I offer how much I drive, how I drive, and how I treat my car, you may not agree with how I treat my car, but like i said, i don't agree with how you treat yours either. I'm at one extreme, you are at the other extreme and if mine is misinformation, then yours would be also, we just treat our cars diffrently is all
As for yourself, you have a choice: You can get bent or you can get educated. I suggest the latter.
both of us are a long way from avarage costs, you don't chage your oil as often as most people, I drive much more then most people, but we each choose how we do it
