Average Yearly Maintenance/upkeep costs?
Jerm
7
O.C.
Hey guys, I've finally decided that I might be ready for the financial responsibilities of owning a MkIII.
Anyway, I was wondering about how much you guys have to pay every year to keep your cars on the road, not insurance-wise, but including gas, tires, repairs and all that jazz.
I know it's going to range from very little to very large sums of money depending on the car and owner, but I'd like to know what I might be getting myself into (be it thick/thin).
Also, many of you guys are going through crazy build ups or something, but I'm hoping I can get at least a little input from guys who are going steady with their mods.
Any guesstimates would be nice :icon_bigg
Thanks
gixxer750
2jzget comingsoon!
Mississippi
honestly..... a lot. I go through tires every 3-4 months....(back ones at least). I have to change plugs about every 3000 miles, and change the oil with mobil 1 synthetic every 1500 miles. Thats about $40 an oil change or so with a good quality filter. I do a lot of modding too, and some repairs when I break stuff. I use quite a bit of gas in it, and some of that includes race gas.
I have owned my car about a year, and have put close to $10k in it, but I am also looking for 500+ hp. This may or may not apply to you, it depends on your goals
born2drv
1,199
Burbank, CA
figure an engine rebuild every 2 yrs..... oh and a tranny rebuild every 2yrs too if you opt for an auto trans.... + $1000/yr for misc electrical sensors/relays/you name it that add up very quickly and other items like alternator, rack and pinion, springs/shocks,etc...., so like $4000/yr.
If you're less then that, it's just bonus money in the bank and you can count your blessings :)
stratoayu
435
surrey
wow u guys must abuse ur cars or something... mines sitting at ~307 rwhp and its been my DD for the last year... all i have done is 3 oil changes ( full synthetic) replaced the starter, battery, thermostat, tranny/rear end fluid... but that was mostly just because i wanted to and in total costed me 300 bux?... annnd yea.. i did put on a bunch of stuff.. but it was by no means mantaince... if something does go wrong with my car.. i do figure out what it is right away and fix it.. its usually small things... my car has seen races.. and some visits to the dyno too... i dunno.. my yearly costs are quite low if i did not mod my car..
robbo185
693
Chicago
ok thats crap.....you dont need an engine build every two years if you do it right and if you build your tranny and cool it properly it will be fine....done listen to him
rakkasan
Currahee!!
Fort Campbell, KY
To expand on what Grim said, it depends on what you goals are. If you want a solid daily driver, you might have to spend $500-$2000 on it depending on the condition of the car when you bought it. If you want to mod the hell out of it, well that's a different story.
SupraDreamPDR
Boost-a-holic!!
Feb 3, 2006
1,140
Springfield, OH.
all i know is that the initial costs of making the car run right and replacing all the old and worn parts (theres alot, its an '88!) is starting to add up. but i figure once i get a solid base of a car, and then its time to rebuild the engine. but after all that it shouldnt be too much of a yearly upkeep.
rakkasan
Currahee!!
Fort Campbell, KY
SupraDreamPDR said:
.....and then its time to rebuild the engine. but after all that it shouldnt be too much of a yearly upkeep.
LOL, I've just about crossed the rebuild bridge.......almost 8K later.....:biglaugh:
xarewhyayen
276 whp - 324 tq @ 13psi
Oct 3, 2005
959
Philly
((salary/2)+bhg*1.73)/4+(rate of inflation)+(Cost of 1 tank of gas*2.5*52)+(cost of good oil+filter*4)+(tires)+etc. etc. etc. etc.
in other words... alot.
A running supra spanking that ricer... Priceless.
born2drv
1,199
Burbank, CA
i just like to figure worst case scenario to someone considering buying this car.... it's very easy to go through 3-4 engines before finding a "good" one if you don't know what you're doing.
8 years ago when i was just a kid, my parents had the engine replaced 3 times because the "JDM engines" installed by professional shops were crap... 2 of those times they got stuck with the bill because it was out of the warranty period... mind you they never came to this website or knew it needed a rebuild with MHG+arps, neither did the mechanics working on them.
Also auto transmissions on these cars are known to fail if pushed hard a lot. I've had mine rebuilt 2 times as well in my youth days... sure I pushed it hard a lot.
But now that I'm older and wiser sure I will rebuild the engine properly and get a tranny cooler, etc. But to the average person buying this car getting work done by the average mechanic, I think there's a lot that can go wrong and they should assume the worst or they'll be dissapointed and just ditch the car after the engine or tranny blows again.
Draken
57
michigan
lets see, for me, 8 oil changes a year @ 3000 miles each, $45 - 50 each, 2 tanks of gas per week, figure at current prices thats around $40ish per tank, front breaks, 50ish....and i still need to go though the whole suspension system and steering system and replace ball joints/bushings and anything else that might be slightly worn..but thats not a yearly expense...new tires, cheap agressive all seasons ran me $300 for all 4, still need some good summer tires
as far as the gas and oil, you have to figure i drive 80+ miles just about EVERY day
stratoayu
435
surrey
ill say that it mostly depends on what type of car you buy then... if you flip a big bill when u first buy the car for one that has been documented and taken care of iwth all receipts since it was new... then your shouldnt be doing bad.. as long as you do keep up with regular matainence... chaning oil regularly with good oil.. not walmart special... i dunno.. i guess there is too many variables.. and if your talking mantaining a car your self, or bringing it to a shop and getting charged up the ying yang for everything... also if your modding it or just keeping it stock...
7M-GTE
ROCK$T@R
Apr 2, 2005
535
KC
They're not cheap if you want any fun out of them... I'm in somewhere around 8K...
EDIT: but I'm shooting for 450hp daily...
americanjebus
Mr. Evergreen
wa.
daily driving, $40 gas tank gets me just over 220 miles, walmart mobil clean 5000 is like $1.95 at walmart per quart, tranny flush with royal purple (expensive ass shit) $10 a quart x 7, not much more than a normal car if you start with a clean condition supra, if you buy an older one with allot more miles, more hoses will need replacing and the price will shoot up for upkeep.
how much you spend will depend on how much performance, and how much care to put into your car. Insurance is most expensive part.
MKIIINA
Destroyer of Turbos
Plano, TX
around 400-600 a year probibly. thats oil changes (mobil 1) plugs every 3k, and usually i break something large once a year (clutch, turbo) so depending on what it is that gave up a touch more or less. mods dont count as upkeep for me :)
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
8 oil changes a year at $40-50 each? Yikes. Ignorance is expensive. My oil expenses are $28 per year, $20 of which is analysis. Once every 3 years (25-30K miles) or so oil cost jumps to $25 when it gets a full change out.
I've found this car to be one of the cheapest, most reliable, and easiest to work on of any I've owned. Depending on how bad it is when you buy it (how hacked up by the previous owner), how badly it was maintained, how much you abuse it, and how much you mod it, it can be spendy at first but otherwise it's pretty cheap to own. If we're talking strickly maintenence costs, mine average somewhere around $150/year. Most years they've been less and some years they've approached zero. The car is pushing 140K miles at this point and runs like a watch. Even has the original turbo.
I do all my own work of course but even then the car rarely needs something. It's all depends on how educated you chose to be and how well you stay on top of things.
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
ive spent about 4000 this year. cdn. but i always seeem to have brake problems. i think mine are wapred... again. always the rear ones. mine sound like they are hiting the pads every spin. gonna go check it out soon :D
Draken
57
michigan
thats 7 quarts of royal purple + filter...15w40 royal purple is $6+ per quart, that gives me 5 quarts to dump in, and 2 extra because my valve guide seals leak slightly and i go though about 1 1/2 - 2 quarts per oil change....don't call someone ignorant if you don't know what kind of product someone is using...and like i said, i drive A LOT and put a lot of miles on my car, and i drive it hard, so i want something that i know is going to hold up in my oil pan, thats why my choice of royal purple oil (and all other fluids), he asked what our cost is, thats my cost, just that simple
