Thanks for all the info, this is some very helpful stuff. -1.0 to 1.1 camber up front was all I could get as well, still running more rear camber (although -1.5 seems better than the -2.0 I used previously) JB weld must be stronger than I thought
Ah, you setup the Hunter for a custom model, mine always shows all red beyond Caster.
Oddly enough I had oversteer for a long time, I've never really had understeer with the car other than tires overheating. Since changing to a heavier front bar (Tanabe, ST rear) it's fairly biased toward oversteer. Maybe if I had more front camber I could run a square tire setup and still not be tail happy? (235/255 now)
Agreed on the rear ratios, I've run those three as well. I know I'm giving up for auto-x using the 3.73 but it works better for me with track stuff (less shifting, I don't go to redline on this engine)
Brian
Brian
