hvyman;1406615 said:manuals are faster
A turbo car is faster with an automatic trans, becuase it will keep the turbo spooled up in between shifts. When it takes longer to shift it manually, but a 5spd is more fun to drive than a auto.
nick88;1406735 said:A turbo car is faster with an automatic trans, becuase it will keep the turbo spooled up in between shifts. When it takes longer to shift it manually, but a 5spd is more fun to drive than a auto.
IJ.;1406617 said:Have had both in my car and MUCH prefer the Auto!![]()
Turbo Habanero;1406975 said:He might of meant stock for stock i would put money on the stick taking the Auto.
Reiketsukan;1407056 said:I can't see where the level of modification would make a difference if both engines were equal in output. An auto still won't loose boost between shifts!
When I first went Supra shopping the first one I looked at was a manual, and the second was an auto. The manual was a POS for sure, but in any event, I still didn't like the feel of the shifter, the clutch, the placement of the shifter or clutch pedal... any of it. I had been driving a GS-R swapped civic hatchback for years, so I was kind of spoiled by it's ergonomics and it's rod-shifted trans. (very crisp, smooth shifting action) Manual Supras just aren't for me, but you should drive them both and see which you prefer!
If that guy with the manual has a receipt for the new turbo, that's a bonus for sure... Drive them both and see what YOU think!
Hvyman said:Manuals are faster
Turbo Habanero;1407085 said:I said i think he meant stock for stock. Cause i beleave that to be true i could be wrong. I was not correcting or doubting anybody.
Koenigturbo;1407052 said::naughty:
IJ how the heck did you get both, manual and auto in the same car? You mean, you automaticly shift your manual or do you manualy shift your auto:3d_frown::3d_frown:
s:naughty:
hvyman;1406615 said:manuals are faster and more fun.
Like my friend would say: "An automatic in a sports car"?
I love my stick shift, I love the side ways feel when it hit's the next gear besides auto's suck up to much power. besides when a auto needs to be rebuilt it's expensive. Most of the time when a stick doesn't work, MOST of the time you replace the clutch, and your good to go. there's not a shop (at least in my experience) that will only replace what's broke in a auto, IE: Clutch pack, they will replace everything.
Manual: it's pretty straight forward, It works or it doesn't......MOST case's, plus they are lighter in weight. Also, no pan to drop to install the filter, no bands to adjust. Auto's are for "Top fuel' racers:naughty:
Drake69;1407126 said:I've heard this too, that autos were faster marginally than sticks. But let's throw a monkey wrench into things (as I'm thinking about getting one of these...).
What difference would a "Suprastick" make in an auto then? Anyone tried a Suprastick yet?
hvyman;1406615 said:what do you prefer? manuals are faster and more fun. autos you have to build if anything over 300hp.
nosechunks;1407176 said::nono: Dont kid yourself, the fastest cars in the world in both straights and twistys are automatic.
Not to mention the Lower Spec boost for automatic cars.
But who cares about stock anyway? No one usually stays stock forever.
