Auto-Xing
I noticed a big reduction in straightline traction going up 1/4 turn of damping on my Koni Coilovers so I can't imagine trying to punch off corners in a powerful stiff Mk3....
prsrcokr
Motörhead
Apr 3, 2005
349
Richmond
drjonez said:
won't help a whole lot. eibachs (and most lowering springs) are progressive rate....better suited for comfort than all out handling.
For the 503rd time I'm going to agree with Adam. They're ok but when you get into the stiffer range it can be a little abrupt. Too soft in the first range which rides good but is where the suspension does alot of it's movement.
I'm still using them though until I can put together a good setup. Suspension's got to move to work just not as much as mine does at times :)
I'd think upper mounts would help tighten the entire suspension, kind of like susp. and subframe bushings. Isolating more movement to the shock/spring, less to the suspension mounts.
flight doc89
Registered Murse
Apr 21, 2006
227
Bessemer, Alabama, United States
wow, teins kick ass.
http://www.alscca.org/solo2/2007/alscca2007may13_sum.htm
'Street Modified' Total Entries: 7
1 Matt Shaddix 03 Black Dodge Neon SRT-4 1:07.680 - -
2 Matthew Curtis 88 White Toyota Supra 1:07.963 0.283 0.283
3 Jared Gould 04 Blue Subaru WRX 1:08.864 0.901 1.184
4 Jessica Gould 04 Blue Subaru WRX 1:09.152 0.288 1.472
5 Brian Cayse 03 Black Subaru WRX 1:11.178 2.026 3.498
6 George Cieutat 03 Black Subaru WRX 1:13.643 2.465 5.963
7 Derrick Paris POS Silver Rental 1:16.645 3.002 8.965
second in class, 25th/63 raw
This car is so much fun, i can actually drift it so-so now. My best times were drifting the shit outta the sweeper turn-around at the end of the lot.
prsrcokr
Motörhead
Apr 3, 2005
349
Richmond
D34DC311 said:
I'm trying to get back into it, Ive got plans this summer for my soop, and they wont let us do it at our parking lot anymore here at tech. Not what your thinking, we did it legally, just someone wrecked into a light, and they pulled the plug on us using the lot.
Tech? Which tech? There's Blue Ridge SCCA if you mean Va Tech.
flight doc89
Registered Murse
Apr 21, 2006
227
prsrcokr said:
Nice job Matt, got a hold on those WRX's. I'm surprised to see a SRT-4 that fast, he must have it setup well.
thanks man. i'm pretty sure that srt-4 was on R-comps. now remember, my car was still handling funny cuz my rear sway wasn't tied in. i'm expecting to do even better once i get some endlinks.
well, i'm gonna be on and off here for a while, no internet connect at home atm. see you guys whenever :)
White Zombie
272
Hampton , VA
so i was looking at going to the teins also. the spring rates on the (Type Flex) style seem awefull high though.does anyone run these on the street? mines a DD but a Auto X warrior also. any reviews would be nice !
prsrcokr
Motörhead
Apr 3, 2005
349
Richmond
Autox warrior in VA? I thought I was the only one, couldn't get any of the local forum guys to even check one out before.
White Zombie
272
Hampton , VA
well I havent been since winter (I sold my yellow MR2 spyder). but im in the tidewater area and eager to see what this puppy will do. SO ANY feedback on those TEINS?
flight doc89
Registered Murse
Apr 21, 2006
227
i dunno about the Type Flex's, i've got Tein HA Driving Masters. They do great on the street, you will feel the bumps in the road a bit more, but it's not bad at all. I was expecting a harsher ride than i'm getting. I wouldn't hesitate to put another set on a DD
Adrian98
182
orange county
i use to run tein HA coilovers i think they were 790lbs in the front 450 rear. this was on my mk4 and i loved them and yes i drove it daily like that with the dampener on the softest setting
flight doc89
Registered Murse
Apr 21, 2006
227
^stiffer sway bars are in order. i need some money for some of those whitelines
mad tyte dori dori
EDIT: how did i pass tech at nationals with a missing lug?
