putting my gearbox back on tonight and the thing wouldnt go on properly ??
wouldnt mate up nicely to the block.
took the box back off because i didnt drive the spigot in all the way and proceeded to do so.
after driving it in to where it should sit, attempted to put the box on again and the same thing.
had a look in the viewing window and noticed that the input shaft was nowhere near the spigott, so that wasnt the problem.
put the 19mm bolts in the bottom most holes on either side of the box, and attempted to slowly and easily pull the box onto the right position.
this was successfull apart from a fingernail gap at the top of the box, which i assume will be zero once i put some bolts in up there as well.
reached inside the box, and spun the clutch plate, ensuring that the spigot isnt inhibiting movement in any way.
only thing i could think of that may have caused this is that the new motor i got had been painted. including the dowels that are on the block which goes into the gearbox.
this may have caused the dowels not to fit into the box properly ( and the problem was mainly at the top part of the box )
my point to all this, is before i start putting everything else back together ( slave, prop shaft, clutch etc ) is there any other reason u guys can think of to explain the problems i have ???
i hate pulling the gearbox on and off all the time, especiallly when i do it by myself all the time
