Aussie MKIII chitchat! (all welcome) NWS
Xistant
xistant
Jun 6, 2005
810
melbourne
sds
ah kk,
255 backing off due to track or limit?
was this with the auto ? or what gear?
soz, top speed is my aim with track as the main forte.
With the gearing I was running then it was only turning high 5000's (motor would rev to 8300 easily)
There was no real limiting factor I was just playing around as I've never had a car that would accelerate that hard at the top end.
1st few times was with the Tremec TKO 5 speed then with the built a340e.
For really high road speeds your combination is in the danger zone.
Low Diff gears high OD % and a motor that will rev lands you a possible starved pinion bearing and at speed it only takes seconds to become square.
If you're serious about going fast I'd look at plumbing a pump and cooler into the diff with the return being between the pinion bearings.
Xistant
xistant
Jun 6, 2005
810
melbourne
sds
have been looking at pumps / coolers, would running lines up to the front to place a pump and cooler be a waste of time or stor it all up next to the fuel filter?
