Aurora Tires
G
gotboost$
Guest
Hey guys,
For some reason my user id was deleted so i started a new one:
former ID: toastem
neways...
Got a question for yall. I have the opportunity to purchase a new set of Aurora tires 255/45w/17 in front and 275/40zr/17 in the rear for like $380.
Has anyone ever heard of these? :confused:
here is a pic of one:
supra90turbo
shaeff is FTMFW!
32
MA, 01440
dood. i sooo would
those look very nice. and when it's all said and done, its not exactly a waste of money @ $95/tire
i would
SupraMario
I think it was the google
The Farm
umm do that shit i payed $119 for my Toyo Proxies4, those look like they are up for the track.
SupraMario
The Farm
hehe Put-it has a point, i was thinking with my eyes. what are the specs and has ne1 run with them before?
ma71supraturbo
Redding, CA
www.geocities.com
Those are the Aurora K103. Anyway, I believe Aurora is a generic brand for Hankook (as if hankook could be called a name-brand). I haven't heard much about them other than they did have a recall a while back for separating (not sure which model tire was affected).
If I were buying them, I wouldn't expect outstanding performance -- but again they're < $100 each.
G
gotboost$
Guest
they do look pretty damn sweet...
I searched the net for quite a while and couldn't find any specs
I'll probably end up getting them because of the cost... the seller gave me a name of a guy running them on his NSX, said he bought 3 pairs of them. i have yet to hear back from him but i will let you guys know if i do...
if they are all they are cracked up to be maybe we can set up this vendor with supraforums and get good discounts.. cheap as hell by themselves, discount would be kick ass! can you imagine paying $75 a tire for 275-17's !!! holy shit
KeithH
Portland, OR
I just did a google.... and I'd be a little suspect of these tires. I was not able to find a single spec on these other than brand, model, and size. No Traction, Temperature, or Treadware ratings.
Remember that your performance is only as good as the weakest link. Don't let your tires be that weakest link.
ma71supraturbo
Redding, CA
www.geocities.com
While I agree with you that good tires can make a world of difference, I put little/no faith in the Uniform Tire Quality Grade Standards (UTQG). Contrary to popular belief, there is no standardized test to establish the numbers. Instead manufactures grade the tires relative to their own other tires. This means you cannot assume that a khumo tire with a treadwear of 300 will wear the same as a pirelli tire with a 300 treadwear. You can only assume that a khumo tire with a 300 treadwear rating will wear the same as another model of khumo tire with a 300 rating.
The traction rating is also misleading. It does not have any relationship to the grip of a tire in the dry. Instead it is simply a "relative" measurement of how well the tire grips during wet skidding. I've seen good tires get "b" ratings despite their overwhelming superiority to models given "AA" ratings (even in wet cornering)
Temperature ratings are also of little/no value. To get an "A" rating, a tire must be able to substain 115 mph without blowing up. Any tire that you buy for the mk3 will at least be H-rated (130mph+), so they will all be temp A. The Aurora tire model in question carries a "W" speed rating (can substain 168mph) for all 17" tires, and at least a "V" rating (can substain 149mph) for all 16" tires ("W" rated tires are optional for the stock size).
I'm in no way endorsing this tire, but I suspect it is a cheap tire that should be competitive with the khumo 712 (ecsta supra).
