3p141592654;1363496 said:Well, you didn't look very hard then. Here is the amp harness. You will note that it plugs into the standard 10p/6p connectors along with the antenna connectors, loops under the carpet to the amp, then back to the console with the funny 14 or 15pin amp connector to the head unit.
Unplug that harness and you have direct access to the 4 speaker channels through the dash 6p/10p connectors.
http://www.cygnusx1.net/Supra/Library/EPC/291420/catalog.aspx?F=8601&P=2
Good call, I completely missed it
