damn.. my car shakes under idle, lol.. but then again i'm on my "get me around while i'm at college 7m-gte" once i get out of school in about a year i'll be buying a fresh block from toyota:evil2: and start from there
jdub said:It's actually torsional harmonic vibration. It's produced when the cylinders fire and the power gets transmitted through the crankshaft, which then takes the brunt of this impact. This causes a twisting motion, the resistance of the crank shaft snaps back to produce vibration. Since there a multiple cylinders doing this, it sets up a harmonic frequency which puts stress on the engine. The better a motor is balanced, the less vibration is produced...that's why you see experienced builders go to the effort to balance and blueprint a motor.
Harmonic vibration causes metal fatigue...specifically in the crank shaft, rods, and the associated bearings. It is not something that will kill your motor right now...the 7M is a beefy engine concerning these parts. It will cause fatigue over time, especially on a high HP motor. This will contribute to 2 failures in a 7M motor...breaking a rod and/or stressing the main/rod bearings.
jdub said:They don't include a crank bolt for any damper they sell...turning the stock one down took 10 minutes max.
Also, the instructions specifically say to heat aluminum hub dampers and to not alter the press fit of the hub in any way. I guess you can hone the hub out contrary to what ATI says...me, I'm going to follow the spec
supra90turbo said:Yeah, I guess it's not a big deal at all.
I wouldn't hone out the hub on the pulley at all.... I'm just curious as to how well it'll come off when the time comes....
Thanks for the info, though, man... definitely good to back up what you say with what the manufacturer suggests... :bigthumb:
Looks like you need a new accordian hose to match all the nice underhood goodies... cooleeze anyone?
starscream5000 said:It would be a little more convenient if ATI supplied a crank bolt that would fit without modification. Hell, as much as the thing cost you would have thought that's what they would do...:icon_neut
starscream5000 said:You wouldn't know of anyone needing to get rid of a good working 100 amp alt like that one do you? Iirc, you do ceramic coatings for ppl right? If so, I may hit you up later on down the road when my rebuild gets rolling.
