Im thinking of some of the more common parts we all buy for our cars and the part number for them so in case you HAVE to order them from a dealer/parts group by part number you can.
I'll throw out some common parts, and you guys throw out the part numbers.
-Green truck shifter bushing
-Plastic bushing on the end of the shifter nose
-Coil pack harness for the 7mGTE
-Rubber / Neoprene hose that connects the valve cover to block
-Parking brake pads
19518-42020 Coil pack harness for the 7mGTE
12263-42010 Rubber / Neoprene hose that connects the valve cover to block
Parking Brake
46540-14020 Front Parking Brake Shoe (RH or LH) (Qty: 2)
46590-14020 Left Rear Parking Brake Shoe (Qty: 1)
46550-14020 Right Rear Parking Brake Shoe (Qty: 1)
Targa
63251-14061 Front targa seal
63252-14032 Rear targa seal:
62383-14052 Pass side targa seal
62384-14052 Driver side targa seal
09169-14010 Targa tool handle
09168-14010 Targa hex bit
09120-14011 Targa toolbag
63296-14010 Cap, removable roof, front
63297-14010 Cap, removable roof, rear
Lock bezel clips
90468-04124 RH Bezel "Offset" Clip
90468-04126 LH Bezel "Offset" Clip
90468-04125 RH and LH Bezel "Straight" Clip
Wiper inserts
85221-YZZB1 Front LH (85221-YTCB1 - Canada)
85221-YZZA9 Front RH (85221-YTCA9 - Canada)
85221-YZZA9 Rear 86.5-88 (85221-YTCA9 - Canada)
85221-YZZC8 Rear 89-92 (85221-YTCC8 - Canada)
Wiper blades
85220-16540 Front LH (86.5-88)
85220-1A020 Front LH (89-92)
85220-3A050 Front RH
85220-32120 Rear (86.5-88)
85220-16441 Rear (89-92)
Wiper arms
85190-14630 Front LH (86.5-88)
85190-14700 Front LH (89-92)
85210-14250 Front RH (86.5-88)
85210-14270 Front RH (89-92)
85190-14680 Rear (86.5-88 N/A)
85190-14690 Rear (87-88 Turbo)
85190-14731 Rear (89-92)
Wiper blade to arm screws
90099-00955 Front (Qty: 4 -- 2 per side)
90099-00913 Rear (Qty: 2)
Fan Shrouds
16711-42010 Main shroud (86.5-88)
16711-42060 Main shroud (89-92)
16702-42010 Lower (No.2) shroud
Fan Clutch
16210-42040 N/A (86.5-88)
16210-42060 N/A (89-92)
16210-42050 Turbo (87-88)
16210-42070 Turbo (89-92)
Tail Light Gaskets
81554-14580 Both Sides (86.5-88) (Qty: 2)
81554-14580 RH Side (89-92)
81564-14610 LH Side (89-92)
Trunk Weatherstripping
67881-14110
Trunk Rubber Stops
90541-09047
Turbo Accordian Hose (AFM to Turbo Housing)
17882-42012
Special Clamps
82710-24010 Brown diag box Engine wire clamp (special order from Japan only)
82711-30070 Black intake runner Engine wire clamp
Under Hood Rubber & Gaskets
15100-42031 7M-GE Oil Pump
15100-42021 7M-GTE Oil Pump
13568-49015 Timing belt
90507-18008 Tensioner spring for timing belt
90916-02364 Power Steering Belt
99365-21290 Water Pump & Alternator Belt (Includes Fan)
99364-20920 Air Conditioner Belt
Starter Overhaul Parts
28226-72080 86.5-90 Battery Side Terminal Kit
28226-72010 86.5-90 Motor Side Terminal Kit
28226-76070 91-92 Battery Side Terminal Kit
28226-74070 91-92 Motor Side Terminal Kit
Engine rebuild / block part numbers
13411-42030 86.5-89 Crankshaft (6M Crankshaft)
13411-42040 90-92 Crankshaft ("7M" Crankshaft)
13612-42020 Oil Pump Drive Shaft
11022-41010 Oil Pump Shaft Bearing Set
90387-26001 Oil Pump Shaft Collar
13011-42060 7M-GE Piston Ring Set (Std Size)
13013-42060 7M-GE Piston Ring Set (0.5mm Oversized)
13011-42011 7M-GTE Piston Ring Set (Std Size)
13013-42012 7M-GTE Piston Ring Set (0.5mm Oversized)
11071-43010-XX No.1 Main Bearing (Qty: 1, Std Size, XX = Size Code)
11701-43010-XX No.2 Main Bearings (Qty: 6, Std Size, XX = Size Code)
11704-43010 Main Bearing Set (0.25mm Undersized, Complete Set)
13041-42010-XX Rod Bearings (Qty: 6, Std Size, XX = Size Code)
13204-42010 Rod Bearing Set (0.25mm Undersized, Complete Set)
11011-43010 Crankshaft Thrust Washer Set (Std Size)
11012-43010 Crankshaft Thrust Washer Set (0.125mm Oversized)
13101-42070-XX 7M-GE Pistons (Qty: 6, Std Size, XX = Size Code)
13103-42070 7M-GE Pistons (Qty: 6, 0.5mm Oversized)
13101-42080-XX 7M-GTE Pistons (Qty: 6, Std Size, XX = Size Code)
13103-42080 7M-GTE Pistons (Qty: 6, 0.5mm Oversized)
96412-43500 Front Frost Plug (Qty: 1, Behind Timing Cover)
96411-44000 Side Frost Plugs (Qty: 7)
96411-43500 Rear Frost Plug (Qty: 1)
Engine
11101-42030 Cylinder Head
11400-42081 86.5-89 7M-GE Short Block (6M Crankshaft)
11400-42140 90-92 7M-GE Short Block ("7M" Crankshaft)
11400-42101 87-89 7M-GTE Short Block (6M Crankshaft)
11400-42102 90-92 7M-GTE Short Block ("7M" Crankshaft)
11401-49596 7M-GE Bare Block
11401-49606 7M-GTE Bare Block
90099-14088 Cam Position Sensor O-Ring
90250-08120 dowel pin for block
22278-42010 Idle Speed Control Gasket (to surge tank)
25628-42020 EGR flange gasket #1(surge)
25627-42030 EGR flange gasket #2 (head)
22271-42040 gasket for throttle body to surge tank
13568-49015 timing belt
13505-42020 timing belt idler pulley
90311-42003 oil pump drive shaft oil seal
90311-52003 crankshaft front oil seal
90311-35017 camshaft oil seal (Qty: 2)
Auto Trans parts
83710-14700 Cable assy, speedo
83770-22120 Adaptor assy, speedo
5-speed conversion for the pressure plate assy.
31231-14040 Hub, clutch release
90201-71001 Washer, plate
90206-72001 Washer, wave
90520-67001 Ring, shaft snap
31264-14040 Spring, clutch
90201-45023 Washer, plate
31470-14050 Cylinder assy, clutch
96152-00450 Ring, snap
28100-45050-84 Starter, reman exhange
90363-12002-77 Bearing, ball (Pilot bearing?)
90363-45012 Bearing, ball. (Throwout bearing?)
R154
33348-35010 R154 1st gear thrustwasher
3110114010 R154 inspection cover
3110214010 R154 inspection cover
3314630020 R154 deflector
Manual Transmission Shifter Parts (R154 & W58)
33505-35020 Shifter Pivot Seat/Bushing (Truck/4Runner Part) - Green in Illustration
33548-31010 Shifter End Bushing - Blue in Illustration
33555-22050 Lower Rubber Shift Boot
33584-22020 Shifter to Transmission Gasket - Red in Illustration
93381-16012 Shifter to Transmission Bolts (Qty: 4)
Fuel Tank
77169-14020 Gasket, Fuel Sender Gage
77169-14010 Gasket, Fuel Pump Bracket
Engine Air Hoses
17348-42010 Hose, Air, #2 (For Idle Speed Control Valve)
17342-42040 Hose, Auxiliary Air Valve, #2 (CBV)
12262-42010 pcv hose to TB
12261-42010 pcv hose to cam cover
12264-42010 Hose, Ventilation, #4 (PCV)
Engine Cooling
16571-42010 Upper Radiator Hose
16572-42020 7M-GE Lower Radiator Hose
16572-42010 7M-GTE Lower Radiator Hose
16401-63010 86.5-92 7M-GE Radiator Cap
16401-63010 87-89 7M-GTE Radiator Cap (Larger Style)
16401-72090 90-92 7M-GTE Radiator Cap (Smaller Style)
90916-03078 Thermostat
16341-35010 Thermostat Gasket
89422-20010 EFI Water Temperature Sensoe
Turbo
04111-42021 Complete turbo gasket kit
15471-58010 turbo to turbo oil pipe gasket
15473-42010 turbo Oil Outlet gasket #2 to block
16347-42020 turbo to no.1 & no.2 water pipe gasket
90430-12005 Gasket For Turbo Oil Inlet Pipe to block (2)
90430-14235 turbo no.2 coolant pipe to water outlet housing union gaskets (2)
96721-19010 o ring for dipstick
Throttle Position Sensor:
89452-20050 - 01/86 to 10/86 7M-GE (RPL 89452-28030)
89452-14050 - 11/86 to 04/93 7M-GE
89452-20050 - 08/86 to 02/89 7M-GTE (RPL 89452-28030)
89452-14050 - 03/89 to 04/93 7M-GTE
89452-22080 - 1JZ-GTE
Exterior
75331-14120-01 Black 91+ Toyota "T" emblem (Only colour available)
81521-14332 Euro half amber half clear front turn signal
81511-14332 Euro half amber half clear front turn signal
-Parking brake pads
Parking Brake
Targa
Lock bezel clips
Wiper inserts
Wiper blades
Wiper arms
Fan Shrouds
Fan Clutch
Tail Light Gaskets
67881-14110
Trunk Rubber Stops
90541-09047
17882-42012
Special Clamps
Engine
Auto Trans parts
R154
Fuel Tank
Engine Air Hoses
Engine Cooling
Turbo
Exterior
