ARP head stud problem
7m2ner
Boosted MA70
Jan 26, 2006
82
Schaumburg, IL
Hey guys, I am putting my engine together now as we speak, and it seems like I have run into a bit of a problem, I have searched and found nothing, as I am torquing the studs onto the block not all of the studs are in equal amounts to one another, I was going to torque them to 80lbs per everyone on here recommended, I have been torquing them in steps 30 60 then 80. I haven't got any 80lbs because I saw this, and I am using the lube that came with the studs. All the holes wore clean before then went in, am I doing something wrong or is this normal?
jdub
Feb 10, 2006
10,730
Valley of the Sun
Did you chase the holes in the block?
Did you put the studs in 1st then place the head on?
shaeff
Kurt is FTMFW x2!!!!
11
Around
^ That was my thought. The studs should only be finger tight in the block, and you should chase the threads before putting the studs in.
Bill UK
90 Supra Turbo 14 psi
Aug 11, 2006
56
UK
As jdub said “ did you chase the holes in the block” ? if the studs don’t screw in far enough you could run out of threads at the top. I knocked up a few drawings when I did mine, they may be of some use.
Bill UK's diagrams show why it's required to get them in all the way, but I think he need to make one of the stock headbolts to show just how little of the holre they use (about half is what I noticed).
First post was right, STOP!! As the studs bottom out, you can crack your block if you tighten them into the block. You say they're all uneven, so that means the threads need to be chased so the studs go in easily...
7m2ner
Boosted MA70
Jan 26, 2006
82
Schaumburg, IL
Thanks guys for all the help, no I had not chases the holes, I am going to chase them now, and no I don't have the head on yet. One more quick question, so the studs are only finger tight in the block, they do not get torqued down? only the nuts?
jdub
Feb 10, 2006
10,730
Valley of the Sun
That is correct...studs finger tight, nuts torqued to 80 ft/lbs using moly (ARP spec). Multiple passes in the TSRM pattern.
One thing often missed torquing on a head...setting proper pre-load:
ARP said:
The friction factor changes from one application to the next. That is, the friction is at its highest value when the fastener is first tightened. Each additional time the fastener is torqued and loosened, this value gets smaller. Eventually the friction levels out and becomes constant for all following repetitions. Therefore, new fasteners should be tightened and loosened through several cycles before applying final torque. The number of times depends on the lubricant. For all situations where ARP lubricants are used, five cycles are required before final torquing.
grimreaper
2,180
Dallas
jdub;1242253 said:
That is correct...studs finger tight, nuts torqued to 80 ft/lbs using moly. Multiple passes in the TSRM pattern.
two things...
what tq value do you go to before loosening & re torquing? And the quote says on NEW hardware, why? i understood it to be the friction between the two surfaces. If they are reused, the same pre-load technique should apply, right/wrong?
jdub
Feb 10, 2006
10,730
Valley of the Sun
I take them up to 70 ft/lbs 1st 2 cycles, 75 ft/lbs 2nd 2 cycles, 80 ft/lbs final torque.
I pre-load regardless if new or used.
so is that heat cycles or before you even start the motor and you just torque break loose torque and so on?
You're burnishing the threads, that's why if they're used they're already broken in and will torque fine. I'm sure this accounts for MOST of the cases of the studs loosening up and needing a retorque.
I wasn't able to do quite finger tight in my block (that and my hands where tired as hell from chasing the threads... they where pretty damn bad), so I used an allen key to get them all the way in easily. You'll know when they bottom out (as they should).
7m2ner
Boosted MA70
Jan 26, 2006
82
Schaumburg, IL
Well thanks again to all for the help, today I spent almost the whole day running around town to find the rite size tap, figures it would be the last store after going to about 15 stores. So i barley had any time to work on it today but I got 3 threads done.
