If your in Christchurch NZ... (I have an old school friend there) its probably earthquake related.. I would overbuild..
IBoughtASupra;1707492 said:Just get new ones, they are cheaper. ARP head studs can be reused but I don't. I believe Ian said he changes the nuts on the studs every six or seven times. I am not sure exactly, but I believe it was him who said that. ARP flywheel bolts are cheap so you might as well get new ones.
Grandavi;1707505 said:If your in Christchurch NZ... (I have an old school friend there) its probably earthquake related.. I would overbuild..
adampecush;1707182 said:Did you modify your torque setting to include the loc-tite on the bolts?
Specified torque is a function of thread condition (e.g. lubricated, dry, etc). A dry torque setting used on loc-tite covered threads would likely exceed the intended preload on the bolts, potentially contributing to the failure.
boostcraver;1707975 said:Any progress on getting the bolts out? Are you looking for a crank yet?
boostcraver;1708807 said:Not tryin' to tell you what to do, but wouldn't it be easier to yank the motor and have good access to the bolts for drilling? Look at it this way: If you muck it up from the under side of the car, you will likely have to pull it and tear down for the replacement crank, not to mention any necessary machine work to accommodate said new crank. If you pull it out of the car and go at it from a good angle, you may be able to do it easier/better and save the tear down part of the job, as well as the other costs. A relatively little bit of work might save you big in the long run. Like I said, not tellin' you what to do, I'm just givin' you some food for thought... (minding my own business again...)
mytmk3;1710157 said:.........unfortunatly missed the track day which is tomorrow I was trying to get ready for
