Aristo swap - Not starting....
IBoughtASupra
4,455
Queens, NY
That is not a problem.
Basically, if you want to test a motor to see if it is running, just send a singal to the ECU to have it "turn on," and then probe the start to crank and it will run. The wiring that is sent out is usually for the body plugs so if that does not work, it is not a problem but you help in solving the issues though. It would not make a difference if the port worked or not since I did not see the "check engine light" illuminate when you turned the ignition on, so you would not be able to check codes anyway.
Someone did not wire that in. Usually when that is not illuminated, it means the ECU is not turning on but since you are getting spark and pulse, it is on but the light is not wired up.
IBoughtASupra
4,455
Queens, NY
He said he believes his diagnostic block is not working, so that would not help.
Your fuel pump should turn on for a second or two when you key on your ignition and then shut off. If you want to jump the fuel pump, use the relay on the passenger side of the engine bay to see if the pump will run if your diagnostic block is not working.
The TSRM has all the relays laid out and their locations.
empera
Authorized Vendor
Philly.
stock aristo injectors were stuck closed....tested each one and only 1 fired....i took a wrench and wacked each one....car now starts :p lol
i will be buying new injectors soon anyway
empera
Authorized Vendor
Philly.
well yea its common knowledge....
i was just weirded out that i had signal to everything....but hey i was the one who broke a cam perfectly enough (BC272) in my 7m to make i still turn the CPS giving me spark, fuel, and timing....broke right after the gear lol
