figgie;1126353 said:Glad you "caught" that
Actually that is the new version of the anti-lag system based on EGR. It works both ways for them
The NEW ALS system that particluar car uses (EVO) is actaully pretty intresting. The "valve" you see on the exhaust manifold serves as the basis to bypass air into the exhaust system while the ECU adds fuel. But instead of the old style where you are dealing with pumping losses to get the air through the engine, this way, unrestricted air is injected directy into the exhaust stream while the unlit fuel comes into the exhaust, at the right time the valve closes, the mixutre lights and you have an ALS that reduces the EGT, is less destructive to both turbo and exhuast parts but still able to maintain race level boost when off throttle with less fuel consumed.
It is actually pretty f'ing brilliant.Also notice no BOV
All that work the turbo did is used to keep the turbo spinning off throttle. So no venting to atmophere for them anymore and if you think about it, why would you when you can keep all that nice pressurized air in the system and help in keeping the turbo spinning.
Keros;935567 said:Just to add a comment here, that on a 4 stroke engine, it's the exhaust stroke (where the exhaust valves are open and the piston moves from bottom to top), that is most likely to cause catastrophic failure at high RPM's. When the exhaust valve is open, the pistons are pushing exhaust out, and there is therefore, no compression to slow the piston down as it approaches the peak of its cycle, this causes the rod (and only the rod) to slow the piston down and prevent it from rocketing through the hood of the car... however, this puts the rod under immense tensile stress, and like all metals, tensile stress is where it is weakest.
On two of the strokes the piston is moving down (compressing the rod) and the other stroke the rod is aided by compression in slowing the piston.
tekdeus;1225020 said:Essentially a BOV into the exhaust to keep the turbo spinning?! If this works, why isn't it seen more often? Any street cars doing this? Or is a huge Tial BOV "good enough"?
Supracentral;1225032 said:Correct. I did a pretty extensive writeup on this very topic quite some time ago.
figgie;1119563 said:F1 motor specifically.
the Bore is double the size of the stroke or put another way. the stroke is excatly half the bore size.
As for your last statement.
WRONG. HP = work but without Torque, nothing will happen (Hp= Work,TQ=Force, RPM = Time). Torque is a force that without TIME (very very important) is does not produce any work (put a 1 lbs weight on your breaker bar that measures 1 ft, means 1 ft/lbs. Problem is the weight is hanging there and not moving. A Force but no work is done). HP and Torque are related. You can have torque but no work done. But you CAN NOT have HP without the Force * time (simple work equation).
Poodles;1122014 said:Nope, it's the crossover point and they're equal.
Take two exact cars (assuming they have the ability and aren't already on the edge of max flow) and spin one up higher than the other. The one that revs higher makes more HP. These cars would be equal until they had to shift and the higher reving car would win as it would be higher in the powerband where there is more torque/horespower.
On a side note, the WRC cars run restricter plates and are tuned for the most power at 5252 RPM. They run out of air and getting more under the curve is the way to more power in their application as their max flow is limited.
supradjza80;1251358 said:I know the equations, this is why i said hp is the important value. Knowing HP implies that you know the Force*time...knowing just the force tells you nothing. So i believe everything written above is correct. If you know you have x amount of HP you know you can always gear the thing for the appropriate torque. If all you know is torque, you really don't know anything because of time...
Furthermore, If you have 500 hp, you have 500 hp. You can gear the torque output of the device producing the horsepower to put out the torque that you need. In a car this is the change in torque at the motor to torque at the wheels.
For example you take the motor out of the semi and properly gear it. This motor produces 425 hp peak in a completely linear fashion, but it only revs to 2000 rpm so the motor produces 1800 lb-ft of torque (i didnt calc this - Im lazy, but its just an example). You put it in a vehicle that weighs 5000lbs total.
Now in the other test vehicle you have a V8 that makes 425 hp in a completely linear fashion and only produces 425 lb-ft of torque (motor revs to 5252 rpm). This motor is properly geared as well and you put it in a vehicle that weighs 5000 lbs.
Now you race - and guess what, since the hp is the same they go the same speed...guess torque is not what really matters and horsepower is really what matters. As long as the vehicle has gears in it, and they are appropriately selected torque means nothing, and HP is what is going to determine how quick the vehicle is.
I know you understand the principals here figgie so I am just guessing any disagreement we have here is semantics based.
figgie;1348777 said:
supradjza80;1348812 said:I don't know what else to say. I have been trying to say this and I guess you just don't get how I am saying this. For the last time horsepower>torque.
Supracentral;1348861 said:Incorrect.
Horsepower equals torque times rpm, divided by 5252
