Hi, First post here as you can see, I usually search to find what I need...but I hope someone can provide some help...
first a little background since I'm a newb here...
I have been working on my 1jz 4runner for well over a year now, and I just got her started the other day. This is my first jz and my first turbo motor. But I have been wrenching on cars since I can remember, and I'm fairly familiar on how engine systems work, and I have amassed lots of knowledge on this motor since I got this crazy idea a year and a half ago... I want to keep the stock twins so no need for the "go-single" comments. I bought my Soarer clip from Jarco some time ago...pristine full clip with hood, less than 47K confirmed on the dash, and the whole clip was in exceptionally good shape. I got it started as soon as it was delivered, and it felt and sounded great. I could hear the turbo's spinning up, and the BOV working properly upon throttle release. It's now in the truck and I've got her started, still a couple of things left before I can actually drive it though. As of now I have gauges for..volts; boost/vac; h2o temp; oil press. I also have some Innovate monitoring stuff hooked up...wideband; rpm; MAP; EGT; timing, but I am waiting for my pcmcia-to-serial converter, until it arrives I have no monitor on the Innovate sensors. 1jz with: intake, 2.5 intercooler piping and upraded intercooler, custom 2.5 to 3" y-pipe, 3" downpipe (cat and muffler not complete yet). other than that, stock Soarer system.
Now for the problem...
-It runs beautifully, just like it did when it was in the clip. BUT it is making no boost (Soarer did not have a boost gauge). It idles at around 22 vac. no tach till I get the Innovate stuff up and going but if had to guess I can rev it up to about 4-5K and no boost, vac lowers to about 12-15, but thats's it!
I'm afraid to run the rpms up without the tach.
-No leaks of any kind, BOV has been removed and checked, it is like new and operates fine.
-I have had the turbos off the motor, both seem to be in good shape, no damage, scars, or stains on any of the wheels, and very little shaft play. I could spin the wheels just fine, but I don't know how much resistance I should feel.
-I can remove the pipe on the intake, and feel air being pumped from the turbo system as I rev it.
-There is the slightest amount of white smoke only when letting off throttle.
-No codes.
I can't think of anything else other than turbo failure, not making enough boost to overcome the vaccuum?? yet still looking and sounding like good turbos from a very clean clip?? I should have my tach up in a day or two then I'll give it some high revs to see if they "wake up" maybe.
For those in the know...Are they shot or can anyone think of something else to check?
Sorry for the long winded post, but I find more info gets to the bottom of things better.
Thanks in advance.
Nick.
-No codes.
Thanks in advance.
Nick.
