Alright it's ordered. I hope it doesn't take a while to figure out how to use it? $291 shipped ebay :icon_bigg 2-3day shipping:naughty:
-MAFT Pro unit: $400
Parts needed if you want to just use it as a MAF translator
-GM 3.5" MAF sensor: $80
-6' MAF extension harness: $18
total: $88
Parts needed to go speed/density:
-IAT: $12
-MAP sensor: $70
-9' speed/density harness: $30
total: $112
Parts needed for boost control (requires MAP sensor and harness):
-high boost solenoid: $70
-9' boost solenoid wiring harnes: $25
total: $95
Optional/Extra Parts:
-6' IAT extension harness: $23
-6' speed/density harness: $25
-6' boost solenoid wiring harness: $25
-Innovate Wideband products: $150 - 400
silverkill said:I'm cheap and on bugget. Maybe buy it later when I get more mods done. I guess safc neo will have to do for now.
:icon_conf I found that page, and about 10 other links to it before I posted. It appears this is for the 1st gen afc, not the 2nd?drjonez said:learn to look harder. from apexi's site:
http://www.apexi-usa.com/pdfWiring/7.pdf
you want diagram T2-b.
89jdm7m said::icon_conf I found that page, and about 10 other links to it before I posted. It appears this is for the 1st gen afc, not the 2nd?
My posts wouldn't even show up last night, so I went ahead and figured it out on my own. Thanks for the help, but i found a safc2 diagram for a sr20, and looking at my ecu pin-out, I figured it out. All I really needed to know was what each wire was for. The manuals also give specific instructions for installation, so it's as straight as straightforward can get. One more question though... Will the knock monitoring function work on our cars?
89jdm7m said:argh... my posts are being moderated????? I also tried to edit in safc 2, but of course the mod chose to leave that part out
87soup;1171088 said:OK i jumped on the wagon... Got my Neo a week ago, installed and love what i know about it so far....
I have a 1JZ stock injectors and turbos, previously if i tried to up boost it would hit fuel cut;
My question: Can the SAFC help me trick my ecu into accepting more boost or are my stock injectors just maxed out?!?!?!?
Also i have read the thread and found out i DO need a WB sensor to tune...
really, I just want some pointers/ direction to take in for my Neo setup...
Thanks!!!
87soup;1171088 said:bunch of neo questions
