AR5 Trans Take Two: The Solstice Solution
Isphius
Supra-less :(
May 30, 2006
359
long branch
I never said carbs were superior...just the first line of my post...cheaper and easier to make more power. I also said FI was better for the street. Of course if you add all kinds of sensors, computer software, etc, its going to run better with more parameters and input to base it off of, I was just trying to say its less work and money to make more power on a v8(notably a chevy, not saying a toyota v8). When i built my 305 monte carlo a few years ago, I just put on a 1975 ish holley 600 cfm, very very used. The way it sat it ran perfect on that motor, not to rich or lean, and made tons of power. The fuel economy of course sucked, but it was liveable. it was about 14-16 mpg average. When i get my license and had that car gas was also 1.30 a gallon so i honestly didnt care..20$ got me a full tank.
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
So, back to the AR5 here for a second:
limequat, when you had the two transmissions apart, trying to swap the rear housings over, did you happen to measure the shafts to see if they were the same diameter/spline?
I would be very interested to see if we could install the triple cone synchro gears into the R154. At the very least, swapping over a taller 1st and/or 5th would make me happy too.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
flubyux2 said:
lol... fate rewards the adventurous.
im sure the UR would be a tight fit since its a 4cam
1uz is a quad cam as well.
Poodles said:
UZ drops in from what I understand (at least with the 90+ subframe)
nope, you would need custom mounts, just like the MKIV supras. I have a 2jz in an sc400, custom motor mounts, ide assume it was the same for a 1uz in something else.
limequat
Dissident
Detroit
They are neither the same diameter nor spline.
Doward
4,245
Alachua, FL
That's right, back from the dead.
Has there been any progress on this in the last year? I've got a 2wd 5 speed Colorado I'm thinking of yanking the transmission out of for the Supra :D
For anyone wondering where that shifter setup is on the Colorado:
limequat
Dissident
Detroit
Have you measured shifter placement with the Colorodo version? I think it would be about 6" forward of the current location...
The Supra is undergoing a super secret motor swap. Here's a teaser:
Hint: Displacement is > 3.5L
Zazzn
l33t M0derat0r (On some other forum) n00blet here
7
Toronto/SF Bay area
wow this topic is completely off topic someone post something about the trans to make me feel like I clicked the right thread!
limequat
Dissident
Detroit
drjonez;1264410 said:
One hint:
Engine code start with an L....
Careful, don't give away my secret ;)
I'm surprised you got it. Even if you recognize the engine on sight, it looks different without the mainfold and cam cover.
