AR5 Trans Take Two: The Solstice Solution
miekedmr
mkiii in hibernation
Jul 12, 2005
513
Upstate NY
I'm doing the same thing, colorado AR5 to 1jz, and my initial attempt to bolt it up seemed to stop about 5mm short. So it would make sense that's whats happening with mine (splines bottoming out.)
Limequat: I take it the input shaft is longer on the colorado trans than the solstice one? You didn't have to do any modification of the input shaft, correct?
The other issue I'm having is the faceplate of the transmission that the SPEC hydraulic throwout sits against seems to be a few millimeters raised versus where it would be on an r154. To get it to sit flat I need to shim the screws that connect the throwout bearing to the bellhousing a few millimeters.
I'm wondering now if putting a plate between the bellhousing and the transmission might solve both problems. (move the face of the transmission back so that it's level with the mounting surface on the bellhousing, as well as moving the input shaft back enough that the splines don't interfere.)
I'm not sure if bringing the shaft back would make the shaft fall short of the pilot bearing though... One things obvious: I need to do more measuring!
And as for not being worth it (in terms of tangible benefit,) I've never been so deluded as to think my time-and-money pit was really "worth it" ;)
limequat
Dissident
Detroit
No modification of the solstice input was required for me. Go figure.
I recommend using the solstice slave cylinder as it bolts up, no modification required.
To me, the biggest hassle/expense was the custom driveshaft. I have some posts in this thread a couple years back. I've since ditched that setup and gone with a solution that uses a stock toyota truck driveshaft. You can mill the output flange on the solstice trans to take a standard toyota pattern. Find the appropriate length and bolt in. Would have saved hundreds off of my swap.
a40ck578g6
Not sure if I should pollute this excellent R154 / MA5 swap thread with my questions.
limequat, et.al. this is some very nice tech and documentation. There's a little chaff too but the good info is easy to pick out if you've done any homework already. As I've looked into an AX15 and derivatives, I have found this site, Pirate4x4.com and Jeeps-Offroad.com not only planting the MA5 seed but providing almost all the info I've needed to determine that I believe my swap can be done successfully....
I'm looking at a swapping an AX-15 to MA5 to run behind a 4.6l stroked Jeep 4.0l. Not your typical Jeep application as this is for my "Street Comanche" rebuild. After 15+ years in the barn... it's time...
Is protocol to start a new thread or do you all think further MA-5 questions should be presented here?
miekedmr
Jul 12, 2005
513
Upstate NY
I made my Colorado transmission + spec clutch combo fit. I'm going to be welding together a solid spacer to replace the washers from 5mm aluminum stock with a TIG. Exactly 5mm of spacing was needed to have the input shaft spin freely in the pilot bearing and the hydraulic throwout sit flat.
d8d5a2533ac464b89cb887325206867e.jpgaa74ce752e586541d3f3027ced84ecb8.jpg35db176c8530f6959af1ee8310bea987.jpg
AlexandreChoquette
4
sherbrooke, québec
can someone can confirm that the hole of the shifter of ma5 from a colorado direct fit on a mkiv? and if the yoke from a kind of supra can fit in the output shaft of this transmission?
subeone;1885584 said:
Come on guys lets bring this swap to light for the entire supra community
so far we know this:
we need a pilot bearing from an e34 540i ( i have verified the dimensions and does work)
we need an ar5 transmission
the slave cylinder setup from the ar5 since im assuming it uses a push method instead of a pull method compared to the w58 and v160
we need a custom driveshaft
an s10 clutch has to be used
a 1jz to 2jz bellhousing has to be used for mkiv, 2jz/1jz, etc. owners.
we need to know the dimensions from a ma5 and an ar5 compared to the r154, it seems that the ma5 from a colorado will straight fit into an mkiv supra, Someone verify or post dimensions in terms of shifter location.
a digital speedometer has to be added for you to have an idea on your mph.
i assume the crossmember works fine for an mkiv?
what about the ar5 taco boxes? anyone experiment with that?
lets bring out more info guys come on
PontiacPwr
Akron, OH
limequat;308768 said:
.....Also, it has the Toyota shift arm attached....
I'm doing a swap of the Solstise Engine And trans into a heavily modified '61 Volvo.
The picture in the original post seems to have the cure for my current problem...
- I need to delete the stock Solstice shifter relocation assembly, it puts the stock shifter back too far...
but the internal trans reverse ball / pivot link is the problem.
I see you solved it with a "Toyota Shift Arm"...
1. can you tell me what year / model(s) I can find this part out of?
2. How far do I need to disassemble the trans to replace the ball link w/ the Toyota Arm?
limequat
Dissident
Detroit
1) Mine came from my stock trans: 1987 Supra Turbo. It should be the same part for any Supra turbo 1987-1992.
2) You'll have to pull of the tail shaft which isn't that big of a job.
thedivision
Can
limequat, can you elaborate please? I would much rather go with a Solstice trans over a Colorado, but I'm not up for making a custom driveshaft to suit the Solstice flange. Were you able to get a Toyota slip yoke to work?
limequat
Dissident
Detroit
Sorry, I don't have pics, as that would make it plain...
But, what I did was use a complete shaft from a late 80s / early nineties Toy truck. It must be a 4WD. 4WD has flanges on both ends and a CV joint or slip joint in the middle.
I then milled the solstice output flange to accept the standard toyota 4wd flange. With this modification, it's a stock/junkyard/$50 driveshaft.
The truck driveshafts came in a variety of lenghts (short cab, extended cab, truck, SUV, etc, etc) but there is one that is the exact right size for a MA5 supra.
Hotcakes0007
5
Tampa Fl
Just got my solstice transmission trying to figure out would it be better to use the solstice internal slave or use my old r154 slave? Also have any better pics of the tail end for the driveshaft?
thedivision
Can
That got me thinking... do you think there's an adapter in existence that goes from the Solstice/GM flange to a regular 1310 u-joint end? That could solve a heap of issues.
limequat
Dissident
Detroit
Good idea. I suggest you make it :)
limequat
Dissident
Detroit
What's your application? If it's a toyota, just use the toyota stuff because it's easier. Also you don't have to pull the trans to fix a slave issue.
Hotcakes0007
5
Tampa Fl
I have a is300 with 2jzgte vvti i had a r154 and stupidly sold most of my stuff from the rage lol. I would like to see the back of your trans so i can figure out how im going to do the driveshaft though im sure its in this thread i think i was having trouble understanding what u did after taking off the rear spline from the ar-5.
limequat
Dissident
Detroit
Lol, too bad!
I've done this swap a few different times in a few different ways. When putting the AR5 behind a 7M, I used the R154 lever, clutch, slave, etc. I had all the parts and all the parts fit together.
But when you don't have all the parts, the internal slave is easier. It's the whole release system in one part. As opposed to sourcing: t o bearing, 1 million different wave springs and washers, slave, lever, pivot ball, etc, etc.
You also might want to consider the type of clutch you want to use. The internal slave can only do a push clutch. If you want a pull clutch, you have to use the R154 stuff.
