apexi turbo timer
My apexi turbo timer wont keep the car running when i turn the key off. my parking brake switch works. Its all hooked up idk what happened. Within the last couple months it would do this but then the next time i went for a drive it would work again but now it just flat out doesn't work. I'm thinking it just might be old and its time for a new one. any thoughts?
thanks kyle
ya i have it set to 40 sec and it shows that. ive switched it to auto and off. ive unplugged it and plugged it back it. if it had a bad ground the display wouldnt show anything correct? i didnt install it so im not completely sure if it grounds in the harness or not. i read the manual and it showed that its a self tapping screw into the body for ground correct?
tissimo
Stock is boring :(
Melbourne, FL
Probably just old and dead. I wouldn't bother buying a new one though. Turbo times are not needed imo.
If you boost the car hard just let it run a few minute before turning off. I usually do a lap around the block and call it a day.
