anyone seen the intake routed like this?
JStoked
646
Edmond, Oklahoma, United States
as the title, has anyone seen it like this?
picking the car up this weekend, and was curious to know if this was a normal approach, or kinda unique?
I plan on fixing it, once I get it and get that kink sorted out.
xzeror
1,356
Miramar, FL
there are a few people who have done so, i dont remember who but someone with black piping had that same setup and it looked pretty clean.
jrot
195
knob noster, MO
two things....can the 1g setup be modded to the 7m cause that looks cool.....
and 2) Jstoked....BOOMER!!!! good to see another okie on here....what part of OK you from....not to thread jack, just curious
bioskyline
1,236
powell river bc
what is the cross section measurements on the 1g pipes?
and looks good, but i see your car is using a cop setup, since the stock coil pack location would interfere with the plumbing. but im assuming the ic has been replaced, as no way the stock 7m ic would allow that kind of routing, not very well in any case.
i was thinking about doing a re plumb but with doing a coil pack relocate, n/a style p/s resavoir and running a 45 off the tb aiming more back at the pass fender
EDIT: i love the zipties holding the rad hose out of the timing gears
A. Jay
Search.
Jun 3, 2009
671
Bay Area, CA
Enough for 210hp, and most want more power than that. OP made a recent thread stating he wants 500.
JStoked
646
Ya that's nice haha. Like I said I just bought it and it has 2jz coils on it
---------- Post added at 06:26 AM ---------- Previous post was at 06:17 AM ----------
O ya I'm from okc
Man.
---------- Post added at 06:39 AM ---------- Previous post was at 06:26 AM ----------
Also I don't even have the car in my possession iv got to go get it Dallas Saturday. I the previous owner sent me that pic and I wanted to post it to see if it's a problem that needs to be addressed soon that all.
jrot
195
knob noster, MO
well poodles has a better eye than i do i guess but right off i would take the proper rad hose with me and fix that before i drove it home....i would personally put the timing cover back on as well but thats your call....the only other thing that really sticks out to me is that is would appear that its venting the BOV to atmosphere but still has the afm in place...i may be wrong on this but that might cause small issues with stalling between shifts and at stops .....but the radiator hose i would fix for sure in dallas....the BOV thing wont keep you from getting home or anything.....
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
yup, seen it..
my friend had it like that on his 7MGTE, but it was actual piping, not just bent couplers...
went to a more conventional 7MGTE setup when he wanted to retain AC, but it looked nice, i'll ask if he has any pics of it..
as for the 1G, yeah those IC pipes are TINY, maybe 2 inches in some areas, my friend has one as well and I love the design, but hate the inner diameter of those pipes..
jrot
195
knob noster, MO
well get a stock one and take it a a gallon of coolant that way if it tears itself up you wont be stranded....or fix it before you head back....either way...
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
This looks like a car that's been owned by McGuyver himself for far too long.
- There are no heat shields on the exhaust manifold and turbo, so check the wiring and hoses above them carefully for cracks. Anything that's hard or brittle will need to be replaced. Pay special attention to the wires that enter the engine harness behind the exhaust side cam gear, it looks like they are all without any protective covering, and the heat / CPS wires there are pretty damn important.
- The previously mentioned bent coupler and radiator hose should be dealt with.
- There doesn't appear to be a battery clamp... and I'm concerned that he might be using bare terminals on the positive side.
- I don't know what he's done with the power steering, but the reservoir doesn't appear to be where it should be.
- That small loop of vacuum hose on the throttle body is wrong.
- The aluminum AC line on the passenger side frame rail looks like it's been kinked.
- If there's only one line running to the boost controller tied to the passenger side strut mount, it's either mounted incorrectly, or it's a bleeder type POS instead of a decent ball and spring.
- The charcoal canister on the firewall passenger side isn't hooked up anymore, which will cause all kinds of mayhem.
- Looks like it's running a filthy K&N air filter, which means it's not actually filtering anything.
- Check that there is space and insulation on the power side from the alternator. I'm always nervous about running anything that conducts - like a big piece of intercooler piping - too close to the high power terminals, like the battery or alternator.
- And lastly, clean those pine needles out of the heater intakes under the windshield. That's ridiculous.
