I was saying just incase you decided on it.
Since you want to know how it spools, on a 7M, I had 10 lbs at around 2800. I did read your post, if you want a better answer, you should list your mods. For all I can tell in that post is that you have a stock 7M to a built 7M dragster.
Cams? Specs?
Port and Polish?
Springs And Retainers?
Stock compression ratio?
Stock ECU?
Aftermarket Tuning Components?
Fuel Setup?
QSV Plans?
T4 Manifold Or Adapter To The Stock Manifold?
As you can see, there is a lot of information left out in your initial post, so please edit it to help others voice their opinion or even better yet, maybe you have a similar setup as someone else.
