Anyone put a Soarer 1JZ into 89+ supra?
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
I guess I got the soarer 1jz instead of the supra 1jz. So, I was wondering if anyone has wired in the soarer 1jz engine harness that would be able to help a soon to be deployed guy. I'm trying to get my swap done before I go to the desert in Jan. Thanks.
RHDMK3
that's it!
Sep 30, 2006
447
Salem, Oregon
It should be a straight foward swap considering that its the same 1JZ that was in the Supra. Unless the 1JZ in question is a VVT-i unit. Is it?
AF1JZ
Jun 26, 2006
3,109
Fredericksburg, VA
I was talking with bigaaron and he told me the engine harness connections to the body harness are different and the motor mount brackets are also different. So, I had some wiring questions.
RacerXJ220
Interdimensional
Abalama
2kV6, what is your job in the Air Force?
I know someone there. You might know them too.
Did you find out what you wanted to know about the 1JZ?
AF1JZ
Jun 26, 2006
3,109
Fredericksburg, VA
Crew Chief on C-17. Who is it that you know here? I need to find out some wiring stuff. So, not yet. I'm kinda low on money and am trying not to buy a supra harness if possible. But, if it comes to it, it's cool. Do you know anything about the soarer 1jz?
RacerXJ220
Interdimensional
Abalama
man, I wish I knew more. I have a soarer engine and cut harness. I'm going with a Stinger EMS, and that's what I'd recommend if I were you.
AF1JZ
Jun 26, 2006
3,109
Fredericksburg, VA
My question is pretty much the connections to the body harness.
RHDMK3
that's it!
Sep 30, 2006
447
Salem, Oregon
Wouldn't a harness from a 1JZ Supra do the job? Unless its a VVT-i unit? As far as the mounts go, I'd just use the ones from a 1JZ Supra as well. Also off topic but what base are you stationed at? I am a vehicle maint. tech at Yokota AB in Tokyo.
AF1JZ
Jun 26, 2006
3,109
Fredericksburg, VA
Sure it would work. Only thing is that I have a soarer harness and I'm trying to save some money by wiring this in the car. I am stationed at McGuire AFB.
NecroCyde
Lurk R
Calgary/Brooks, Alberta Canada
well, from what my research shows, the soarer a340 is stronger then the supra a342e. the soarer auto tranny is closer to the mark 4 supras beefy stock auto. mounts would be an issue anyways, but from what ive heard, you just need to move them around on the block, i think there too far forward in there mounting position. the harness is a real whore apparently being quite dissimilar to a mk3s body wiring and closer to a mark 4s wiring. if your using your r154, the same bellhousing issues arise, it can be done, just make sure the engine isnt a front sump, lol
AF1JZ
Jun 26, 2006
3,109
Fredericksburg, VA
I am already using the r154 with 1jz bellhousing. My question is about the engine harness connecting to the body harness. Thank though.
89supturbo
186
Delmar, NY
you could always just make it work by sikdering wires frmo the ECu to the supra body harness or use a standalone either way it looks like you're in for hours of wiring fun
AF1JZ
Jun 26, 2006
3,109
Fredericksburg, VA
Yea, i guess I could do that. Do you know which one I need to wire to the body harness?
89supturbo
186
Delmar, NY
I'm not sure but your going to have to get a soarer and supra wiring diagram and on the diagram it should say which clip goes to the body harness
joey_daze
KILL UR CORPORATE MASTERS
Apr 6, 2005
72
Tung Chung, Hong Kong
a friend of mine on SF is in the process of creating a Excel spreadsheet of the pinouts for the soarer harness to connect to the supra. It has been done already.
