Anyone have any problem with their gas doors?
Doward
4,245
Alachua, FL
Seems like all the supras I've seen, the gas door hinge is always bent!
Anyone know why this is, or any ways to fix it? Now my own is bent, and won't pop open on it's own - the cable is fine :(
daledoe
KILL U
Nov 18, 2005
1,467
MAINE
Mine is missing the rubber part!!!! But ya alot of the supras I see have something wrong with them.
johnathan1
Supra =
Aug 19, 2005
5,056
The one on my NA used to work fine...but this one used to be just open all the time (previous owner removed spring and latch when the cable popped off) I popped the cable back on, and got a spring and latch from Suprahero, and now it will stay closed, but when you go to pull the latch to open it, you have to pull on the door itself a little and it opens...much safer than before...and now there isn't any chance of anything happening to my gas (vandalism, theft, etc...). thanks Suprahero!!!!!
fiyota
I ♥ Boost
May 3, 2006
1,063
Kelowna, BC
mine was bent and kinda off centre... so I straightened the hinge and then bent it outwards a bit on the bottom... now it looks like new!
Disced
Pie + NYQuil = FTW
Edmonds, Wa
I have to wedge something underneath it; and then go pull it out. It doesn't pop out at all. Only car I have ever experienced this problem with.
tsuper92
supra addict
Apr 7, 2005
1,376
mass
a couple of time's mine wouldn't open.i guess the cable was stretched.i did a little quick fix once i got it open.i took a file to the little black plunger that holds it shut.i filed it down a little,now it open's every shot.i got a new cable for it,but waiting till i get a new rug to install it.
Insidious Surmiser
Formerly 89jdm7m
May 12, 2006
2,172
Oceanfront
mine would scrape on the inside when you opened it... i just put some washers on the hinge for shims... a little tough to pull the latch, but it doesn't scrape
Insidious Surmiser
Formerly 89jdm7m
May 12, 2006
2,172
Oceanfront
ValgeKotkas said:
Seems like you turbo guys tank too much ;) execp JAV (no money...:))
i'm getting around 25 mpg when i run it propperly.... maybee more than that, and yes, i usually do drive like an old lady (in terms of speed, nothing else :)), unless the occasion calls for me to do otherwise :evil2:
