RazoE;1056531 said:I have this exact muffler..
http://www.procarparts.com/product_info.php?products_id=7157&osCsid=2e766df61e206c2537aef9243b24b066
with crush bent 2.5 inch piping following the stock path with no resonator....
it's nice and deep (can set off alarms when I let go of the gas), but very very silent at idle once it's warmed up, and it's quieter than stock at around 2.5k rpms
CRE said:Sound clips: 1 2 3 4
I stripped out the video, it was too dark and the camera wouldn't focus. I must say, it's sooooo much quieter when you're in the car (not at WOT though).
The gravel like noise is the studded tires I've got on the rear of the car.
EDIT: I'm running a stock cat, 2.5" pipe and a Borla ProXS muffler.
CRE;1056512 said:I have a VERY smooth, deep and LOUD AS HELL exhaust....
Sounds good CRE, but I want to hear it at 6500CRE;1056797 said:These don't really do it justice, but this is all I've got as far as sound clips are concerned:
(Copied from an earlier post of mine)
I should add that I do not have a resonator installed right now and the muffler is a single tip... a dual tip will probably quiet things down a tiny bit more.
AJ'S 88NA;1057096 said:Sounds good CRE, but I want to hear it at 6500![]()
CRE;1057149 said:Hehe... I've got to say that in the higher RPM and at WOT it sounds pretty mean if you're driving next to a concrete barrier or, better yet, if you're in a tunnel.
