The first car that I had these issues with, gave a knocking sound like a center support bearing noise. I lifted the car up and the cradle was cracked in about 7 different spots. We replaced the cradle and welded strips of steel over the spots where the cradle had cracked. I run into this issue on 4 other cars, and repeated the first procedure. However, on my car. The cradle did not crack, the differential housing itself twisted inside the cradle. It moved clockwise and opened up the bolt holes to where the diff bolts to the back of the cradle. I have not checked the top bolts to see if they opened the bolt holes, but I do know that every bolt in the entire housing/cradle are tight. Has anyone else had issues like this and how were they corrected???
