jetjock said:Unfortunately there's almost as much ignorance, myth, and misconception out there about ignition components as there is about oil.
I completely respect your opinion & knowledge. My actual exprience with them was not good. When I started having the miss the last thing I thought it would have been the plugs but I got a new set of Champions to replace since I was going to take the old ones out to inspect the engine anyway. To my suprize that when I found the cracked plugs. Installed the new champions
w/o a 2nd thought & it cured the problem. Drove the car a few thousand miles & found the same problem with the new set, cracked insulator. This time on #2 & #6. These were the Plat. plugs. Don't remember the # but ran about $5 ea. Could the specs on Aviation plugs be higher then that of auto applications?
