I already bought the fluid and the pump. I tried using a long bar to get some torque on it but it wont budge. Will buying some PB Blaster help??
Very much this. ALWAYS remove the fill bolt first, ALWAYS use a 6-point socket, and ALWAYS make sure you have a snug fit before turning the breaker bar/ratchet.super51fan;1919344 said:1st trick don't drain fluid till you remove fill plug. It is very hard to turn car upside down to refill...
