Any other benefit on OEM coolant through the throttle body setup?
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
I think the "horsepower gain" story came from since there isnt hot coolant flowing thru the TB it doesnt heat the IM or the intake air as much so you might gain some hp. Ive seen datalogs of IAT's dropping up to ~10*F just from bypassing the TB coolant, but as for the HP gain ive seen no evidence. Works on the same principle as those IM gasket spacers to keep the head from heating then IM. I doubt it matters on a turbo engine anyways.
jsnowman76
In need of another supra
Oct 17, 2006
289
Elk grove, CA
showthread.php
if you can get the link inside this thread its should tell you what you need to know.
james_9876
Rehabilitation time...
Aug 1, 2007
183
Spartanburg, SC
Basically... Unhook the hoses from the TB. Insert a 3/8" hose connecter into both lines. Tighten one clamp on each hose. And you're done.
Any ?'s ? Just ask.
Later
