Antilag
Tun_x
Built to do the NASTY!!
Utah
Im gonna drive it a little today and i will try to get some video.. I have to be careful on the street as it is very loud with just a 4" dump and the high compression
Tun_x
Utah
tissimo said:
8 psi? just a 2 step? anti lag i can get 18 psi at 4600 rpm on my 67.. probably mor ethen that..
It is not tunned at all I simply set it up and turned it on ..
Dec 3, 2003
6,653
Canada
Doesn't really matter of how much boost you can build, it is how you hook. I have run a best of 1.5 60ft on my 7PSI off the line. I know a guy with anitlag with the AEM and runs 20PSI. His 60fts are almost the same as mine ;)
Go get some video footage TunX!
Duane
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
i plan to do this when ever i go stand alone
witch will be doen as sson hit mu number wiht my lex setup
Tun_x
Utah
So I was out working on my car tonight as usual and ran into something that bothers me ...The E6k can control Antilag or the nitrous but not both.. I know I dont want an ugly micro switch under my hood . I can use a Tps switch... but that cost more money... So my Question is if you had to choose between the nitrous and the antilag which would you choose? I will eventualy have both but not tonight
Tun_x
Utah
I wonder which will benifit me more at the track I can use the 2 step on my msd box it has a 2 step retard as well and think that would probably get me out of the hole ok .. I dont know if my turbo is to large to spool with it though
Disced
Pie + NYQuil = FTW
Edmonds, Wa
I'd still go antilag. Spraying off the line isn't really the best thing to do... You'll say bye bye to first fast if your on a 5 spd.
Dec 3, 2003
6,653
Canada
A friend has nitrous off the line and anitlag. You should see this car launch! I would pick antilag. The AEM can control the rest. I will be hooking up my set-up similar to this.
Duane
gravesdu_99
255
Potsdam
Hey I got a supra that is close to stock for right now. But I would like to get an antilag or rev-lauch controller, which ever you like to call it. I see a link for the technosquare controller. Does anybody have this or any over controller, how much does it cost and where can I get it. The web site is underconstruction.
