Antenna replacement?
reydio
181
Pearl City
Midnight Dorifuta;1393024 said:
Did it improve reception?
I was considering a 4' long FireStik, just for the fact I'd also get pretty good CB reception and are planning on adding a CB radio soon as well. But it looks kinda 'lol'. I don't want to lose reception, I definitely want the ability to lock into more HD stations... that's why I replaced the awesome factory HU with my JVC KD-HDR50. D:
Receptions is awesome, I am currently using it with HD stations. I like it for the fact that it properly seals the hole with no modification. I noticed they have a new model that is twice the amount, the Fuba Betaflex-D, with a little longer and skinny stem 18" versus 7".
fonz87
89 Turbo!!!!
Nov 17, 2007
642
Streamwood, IL
supradjza80;1393235 said:
looks like an 87/88 so it probably has the 1 piece spoiler
haha i missed that, well anyone here has replaced the stock antenna with something short and different on a 89 + with 3 piece spoiler ?
supraman666
124
PAWTUCKET RI
i used a cressida antena but have to leave it extended. it dosent go in and out of the 89+ spoiler but bolted up and pluged in like stock. 10 bucks at junkyard
Last I knew they didn't still have the NA/pre-89 style anymore. Could be wrong but I know several locals got new antennas and they were all the extended type for the 3 piece wing.
JDMMA70
2,550
Houston
I got my Pre89 Antenna brand new. Its just a rod some camry's use the same one. Easy to install too took me 10min.
dragracer
GearHead
Oct 31, 2005
221
Churubusco
If you have a working factory antenna, then order a replacement mast from Toyota. There should be no other option.
The mast isnt that much and is easy to replace.
RedComet13
Rock n Rolla
Mar 6, 2008
113
San Antonio, TX
I removed my Antennae, Wiring, the plastic pieces that retain it And Filled the hole and painted it to prevent Slight leaks. But then again I had a stereo/speaker/rear setup removal done so It was only one of a series of removals that I was performing for race conversion. Plus I always thought the stock made my Sup look like It was an actual Sized RC car. Just thought I'd throw in my 2 cents as a possibilty if you were ever going to do a rear setup removal or Auto X. :biglaugh:
