I know its impossible for anyone to definitely diagnose rod knock over the internet, but I am just looking for some outside input....
Rebuilt 7m, arp hardware, probe pistons, mhg etc. Oil was in motor upon start up but remote filter setup had a crossed line causing no oil pressure. Yippee. Motor was started and run 2 or 3 times for 30 seconds or less until the problem was figured out. Was this enough time to completely trash my motor? Maybe.
Oil pressure seems normal, at 2000 its about 20psi and goes up with rpms accordingly. Mechanical gauge doesn't show the low numbers the best I can tell its at 4-7psi at idle (tsrm states 4psi as minimum as it is a full flow system not high pressure)
Knocking sound isn’t there upon startup, it starts after car is fully warm and is kind of intermittent. unplugging injectors one at a time does not make it go away (but could be multiple cylinders bad), crank pulley is tightened to 195lbs, cam gears and timing belt tensioner are tightened to 36lbs. ran it with all belts off no change (except my alternator is making a rattling / whining sound but not the knock sound). I have put a stethoscope all over the motor but I cannot pinpoint it down anywhere:
http://www.youtube.com/watch?v=nMjJS2XZR_g
Knocking is loudest at idle and is harder to hear when rpm increase. I did some break in runs when it was idling high and before I noticed the knock. Got the idle down to 650 rpm where the knocking was more noticeable I have not been driving it since. Thought I had it timed right but it seems to be running 15 degrees btdc now, but it would need to be advanced for detonation knock wouldn’t it?
I also thought rod knock would be more evident at higher rpm than at idle... does this sound like rod knock? I have not personally heard rod knock before so I am not sure.
Don’t know what to do now... pretty depressed about it.
