Sorry for bringing this issue up again im just in need of some major help.
I have an 87 supra with the 7-MGTE engine in it. when i bought the car everything was fine, never had a problem out of it. here recently the car has been acting up, dying out of nowhere then cranking over but not starting at all. after a few minutes of fiddling with wires (the CPS and coil packs and others) it would eventually start back up and run fine for a day or two if im lucky. Well it finally stopped and now its not starting at all. will turn over but no start. Tested fuel pressure; excellent, texted compression, fine. tested spark next. it seemed as though two coil packs werent sparking but one was so i bought all new coil packs. When i put the on my car and hooked everything up, made sure grounds were good, and tested those coil packs im not getting spark at all.
I have power to the coil packs themselves, i have good Ohm readings coming from the CPS also. also made sure all connectors going to ECU were in nice and snug. The only thing i havent done is checked the igniter(not even sure how to) or hardwired the CPS, which i think im going to do in the morning. i have no idea what else i should check, all i know is the coil packs arent getting the signal to spark the plugs they just have power going to them. i have also checked all fuses. Any help will be greatly appreaciated. very very sick of this problem :3d_frown:
