Well as I previoulsy posted I just got my motor done.....I put in the Lex AFM and the PTE 550's with a AFPR. Before when i would start the car the idle would sputter and go in and out b/w 1000 and 1200 until normal operating temperature and then would go away and idle normally at about 650. Now it is sputtering all the time. It is sputtering through the gears (the first 3 anyways) so I am thinking it is a misfire. I have no codes, running 36 psi of fuel at idle, and my wideband is reading about 15.9-16.2 during the sputter at idle but every once in a while will suddenly jump to above 17. Ignition timing is set to 12 degrees and the cam timing is dead on. I don't know where to go from here so any input would be appreciated...Thanks guys!
