Here's what I've checked
Boost leak test
Gapped plugs to .028 then to .023 (no difference)
Using Walbro 255lph pump
TPS hasn't been touched although it could be a problem
Car idles fine/drives fine
Replaced caps on ECU
Car is a Manual with manual ECU
Plugs not fouled
Swapped map sensors/no difference
Unplugged TPS- same behavior
Revs limited to approximately 4000rpm.
Questions as I spend hours searching..
What is the pigtail 4 pin connector for that comes off the ECU (JZA70)
The TPS is getting 12v on the yellow and blue wire
The black and Blue wire is getting 5. Not sure if that's okay.
Thanks for any help.
Alex
Boost leak test
Plugs not fouled
Alex
