Justin727 said:
sounds like a good plan. You have any ideas besides detonation that could have done this. What grade gas were you running and at what boost?
Well i hope it was not Detonation cause then i have to run Race Fuel LOL!
Stock boost with full 3" Exhast turbo back no Cat
I use 91 or higher Octane always, usualy it's 94 that i get from a particular station around town here.
I know when i first ran the car the timing was off from the CPS, didn't think it was going to be to big of an issue since i was far from home and well had to get the car home. Could afford the tow at the time would have been about $300
I am wondering if the last guy who put my Cams in put them in wrong some how.
Looking at the head and the Block i did not see any problems with anything other then the obvious stuff that leake dinto the cyl. from the BHG
If you have any ideas let me know. I was about to tourque down the head again with the stocker in there.
Also do you think my water pump might be fried from all this abuse or will it still be ok
