Another ?? about wheels! Great Deal!!
mhopemk3
The CT install SPECIALIST
Jul 13, 2005
762
Jacksonville, FL 32277
Just an FYI for all the responses.. Here are 2 of them mounted with no rubbing... Sorry these are on my camera phone..
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Did you turn your steering wheel both ways completely to see if there is any binding or touching of wheel to fender well? How much room is there on the back set from the suspension?
mhopemk3
Jul 13, 2005
762
Yep I checked.. In the rear I had to push the tip of my finger between the wheel and strut.. Maybe 1/2 inch or less. No issues with hitting the fender on the rear unless I hit a huge hole and compress ed the suspension like 3-4 inches. The front was about the same. 1 finger tip beween the tire and the plastic in the wheel well. Maybe would rub the plastic if the car leaned enough..
I have ST springs with KYB's as well..
I also used the Tire calc and suprising enough that the overall wheel for the 19 is .06 smaller than the 245x50x16 on there now.
Sawbladz
1,727
Oshawa, ON, CA
I like the style of wheel because they don't look heavy. Regardless of whether they are heavy or not, the large diameter and thin spokes gives the feeling of alot of free space and makes the wheels seem lighter. IMO.
I personally would take an 17/18 over the 19 any day of the week, but given the situation...I'd roll the baller 19's:naughty:
Also...did you ever state what the tire size was front and back?
EDIT: yes you did. Do the 275's look stretched on the 10 inch rim?
mhopemk3
Jul 13, 2005
762
They do look a little stretched.. Not as bad as some others I've seen.. But the edge of the rim is not flush with the side of the tire.. Curb it and it would be rough.. One of a couple of reasons I may back off from the purchase.. I always thought 18's would be the biggest I would go..
twinturbozs
131
san francisco
I think 19's look great.
