hello everybody. so I keep searching, but the more I read the more I get confused. my water pump started to weep when I put my car back together this week and now there is vary noticeable wobble in the pump pulley. so obviously I need a new pump(2jz), but idk what to buy. the pump is two separate pieces, correct? do I need both or just the front piece? where should I buy it? are ebay ones any good? I know "satan" on here used an ebay one. I was also going to change my timing belt so to confirm the 88 trooper belt will work, right? and should I replace my tensioner as well, even though its working fine? will the 2jz tensioner work? sorry for all the questions.
thanks,
Kelson
thanks,
Kelson
