AN size for power steering hose need to know ASAP
Cz.
CAR > FAMILY
Seattle, WA
This may not be the exact measurements, but it is what I'm doing.
10 AN from reservoir to pump
DM line from pump to rack
6 AN from rack back to reservoir.
jza240sx
Formerly jz240kouki
Jul 18, 2009
185
New Jersey
10AN is to small from resorvoir to the pump.
Loose Seal
Cressy Lurker
Feb 5, 2008
10
Midwest
How do you figure?
-10 reservoir to pump.
-6 everywhere else.
That's the standard for PS that I've seen, installed, used, etc on several cars of various makes and purposes.
jza240sx
Formerly jz240kouki
Jul 18, 2009
185
New Jersey
Loose Seal;1464957 said:
How do you figure?
-6 everywhere else.
because i put 10AN hose on my pump and it doesnt work...6 works but not the 10AN..
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
Could you specify which case didnt work for you?
You mean the -10 wont work from pump to reservoir,
or -10 doesnt work from cooler to reservoir/ from pinion to pump.
It looks like -10 will work from the reservoir to the pump inlet!
It looks like its all flanged for a rubber hose though but I am sure it would be mostly for looks anyways since its not under pressure and the rubber hose works better you could maybe do a dress up kit for braided hose apearance or even tap coupler fittings for 100% an hose -10 lots of extra work though.
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
My 2j pump to resevoir inlet is smaller than -10... Works fine. -10 is larger in inside diameter than the 2j pump inlet.
I dont see why -10 is too small.
