am i just being picky about my water pump
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
well reson i asking this is orderd and oem replacment water pump aka not asin i got a npw
whne i open the box i was like oooooooo new then fliped it around to see a donkey piss trubine wheel that is cast and not stamped steel like the asin one
i pretty much made up my mind not to use it since ummm 7m like water that kidna moves
npw http://www.joetlc.com/images/1701820a.jpg
stock is asin witch are stamped and sharped edges
i i worn all of you these's are crap oem or re man that is all i got to say
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
you are being picky... the toyota one is not that much bigger, and it has thinner blades. that would mean it wouldn't push as much. or you can do what i did and weld a plate on it to make it push even more.
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
I recall this having been talked about before on here. IIRC, someone got a new Aisin and it had a cast impeller too. I guess they're cheaper or easier to manufacture.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
wow this is the frist time i ahve sean cast turbine
guess i will live wiht it but in the back of my head it will bug me
i still woundering on croay slashes weld thing and why
Mk3runner
2,033
Nor Cal
I'm using the water pump that driftmotion sells, $55 and works great. I think toyota quoted me like $150 or something for a new one.. I figure people can buy what they want. I think you're being a little picky but at the same time I'm the same way with other things.
Doward
4,245
Alachua, FL
Never seen a cast one, here... I'll snag a pic of my STAMPED STEEL impeller when I get home.
BTW, mine's a new one I bought from Advance Auto Parts ;)
GetBoost
76
Fayetteville
Nash I have to agree with you man, the one i took out of my car was like the one in your picture. Replaced it with one from toyota and couldnt beleive the difference. The blades look so much better on the toyota water pump! On a side note though, I didnt have any problems with the other water pump til it went out. After seeing both though I will stick with toyota!
dbsupra90
toonar
indiucky
i have a new one from toyota. i dont remember the exact price, but it was around $65 from elmhurst w/ discount.
stuff like water pumps, oil pumps, etc i will only use toyota. i guess im just anal about stuff like that.
I want pics of these stamped ones... I'd compare the dimensions to see if there is really any benefits to running the OEM one...
NashMan
Aug 5, 2005
4,940
17
Victoria BC
dude you can cut your finger on the blades there shapened and crazy talerances
this one looks liek kid made it in meatle work lerning how to poor meatle
but since it is not hot here i going to use it but as soon as i find chnace to replace it it so getting the boot \
all so like to add one of the most enginner things on a out bord motor is it's prop be sides the haul it self
crisp
existentialincrementalist
May 25, 2007
1,785
Ohio
New to site... old to supras and "otherwise"...
I noticed DRAMATIC distinctions between an aftermarket POTMETAL CAST impeller and the AISIN unit. I took my aftermarket back (this is half-a-dozen years ago... or more...) and got the AISIN unit with stamped impeller. Then I "polished" the fins to take off the "rough" edges from the die shear.
Couldn't say if it DOES make a difference without empirical evidence... but the APPEARANCES are pretty notable... enough for me, in this case.
my .02
-crisp
