Alternator problem, Low voltage, please check my work. Saturday morning I go to start the car and I get a sluggish start. I'm on my way to make an errand so I stop by the auto parts store to check the battery. They check the battery in the car with a black box of sorts and they report that the battery is good but it has a low charge and the alternator failed the test. I go home and pull up the TSRM and grab my digital voltmeter. I don't have a ammeter that goes over 10amps so I could not test the output in amps. Belts are tight, no slipping and the contacts on the battery are all clean and tight. All measurements were done at the B terminal on the alternator. Load measurements were done with the high beams on and high heater fan. I checked the dash light and the light does work.
According to the tsrm. If I bypass the IC regulator and your V readings are "less than standard" the alternator is at fault not the IC. My readings are border line. At cold temps my alternator seems OK but as the underhood temps rise and the alternator gets hot my volt readings start to drop near the low side of specs.
My diagnosis... Failing alternator......Maybe? No starting issues for two days now.
Opinions please.
- Hot engine @ idle 13.29v, 2000rpm 13.8v
- Hot engine with load, idle 12.29v, 2000rpm 13.35v
- Grounded the IC at terminal F per the tsrm, idle 13.4v, 2000rpm 13.85
- 12.16v volts at the battery engine off.
- Cold start, idle, 14.5v
- 2000 rpm, 14.7v
- Alternator getting hotter @ 145F, idle, 14.0v
- Arrived at work, alt temp 185F, idle no load, 13.8v
- Arrived at work, alt temp 185F with load 12.5v
- alt temp 185F, no load @ 2000rpm 13.8v
- alt temp 185F with load, 2000rpm, 13.8v
- 14.5v at idle no load
- 13.7v idle with load
- 12.5 volts at the battery with the engine off.
Opinions please.
